12-28-2009 06:19 AM - edited 03-06-2019 09:05 AM
Hi All,
I have a dumb question...
I have a Cat4506, Sup II+ with default 32mb onboard flash. I would like to upgrade the IOS to 12.2(53)SG1, which requires 64mb flash.
If I purchase a 64mb flash card to stick in the slot on the supervisor....
Can I insert the card on the fly or will the switch need to be brought down first?
Can I boot an image off the "External" flash? Would I still use boot system bootflash:<image> or would it be like slot0:?
Thanks.
Solved! Go to Solution.
12-28-2009 06:25 AM
I have done this on the fly and had no issues. Before doing anything I would format the flash in the switch before moving forward with loading the new IOS on it.
There are times when the card will not be recognized, so make sure you can see the card before proceeding too.
12-28-2009 06:46 AM
Yes, you can just insert it into the slot. You do not need to bring down the switch.
Once it is in the switch, then load the IOS using copy tftp slot0;
and reboot the box.
To make sure every thing is working properly, I would do this during an outage window not during business hours.
Reza
12-28-2009 06:25 AM
12-28-2009 06:46 AM
and reboot the box.
Reza
