enable routing on cat 2970
sadam2006
is it possible to enable inter-vlan rouitng on cisco switch 2970 i tried but fiald
hi sadam,
since 2970 is a layer 2 switch, you won't find "ip routing" command on to it.
sourabhagarwal
Level 4
Level 4
cisco 2970 is Layer 2 Managed Ethernet Switch.
since it is not a layer 3 switch, it is not possible to configure inter-vlan routing on it.
rate if it helps ...
hi sadam,
Hi friend,
As posted earlier the 2970 is a layer 2 switch and hence does not support inter vlan routing.
You should consider using a 3550,3560,3750 or
above for inter vlan routing
Narayan
