enabling snmpv3 on nexus 7000
robertkwild
hi all,
everytime i run this command to enable snmpv3 i get an invalid command
snmp-server user user01 network-admin v3 auth sha password  priv aes-128 password
% Invalid command at '^' marker.
thanks,
rob
balaji.bandi
Hope you are doing, in config mode right ?
snmp-server user name [auth {md5 | sha} passphrase [auto] [priv [aes-128] passphrase] [engineID id]
Example:
switch(config)# snmp-server user NMS auth sha abcd1234 priv abcdefgh engineID 00:00:00:63:00:01:00:10:20:15:10:03
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/system-management/guide/b_Cisco_Nexus_7000_Series_NX-OS_System_Management_Configuration_Guide-RI/configuring_snmp.html#con_1057347
BB
Christopher Hart
Hello!
Can you share what NX-OS software release this Nexus 7000 switch is running?
The syntax of the command you shared appears to be fine. Support for SNMPv3 was added in NX-OS software release 6.2(2), so you need to be running that version or higher in order to configure an SNMPv3 user.
Thank you!
-Christopher
