Bookmark
Subscribe
5362
encpsulation dot1q - trunk SG300 issue
mbaqi0001
I have SG300-28 28-Port Gigabit Managed Switch (Firmware version: 1.3.0.62 ). I'd like to create a trunk port to allow VLan ID 300, and here is my configuration
#int gi3
#no negotiation
#switchport mode trunk
#switchport trunk allowed vlan add 300
#spanning-tree portfast
#exit
And I'd like to enable encapsulation dot1q on that trunk "#switchport trunk encapsulation dot1q" but it is not allowed on this Cisco ("unrecongized command").I actually I will send the packet from Esxi which supports only dot1q not ISL
Any help would be greatly appreciated. Thanks
2 Accepted Solutions
Ganesh Hariharan
Check out the below link , Hope that Helps.
Cisco SG 200 Trunking
Hope it Helps..
-GI
This is normal. SG300 switch doesn't support ISL protocol, so there is no need in the command "switchport trunk encapsulation <trunk_protocol>". All trunk interfaces use dot1q to encapsulate ethernet frames on SG300.
Ganesh Hariharan
Hope it Helps..
-GI
Thank you so much for your reply. Vlan is always up "no shutdown" by default ? as it is the same thing "unrecongized command" on the Switch.
