Bookmark
Subscribe
1640
EtherChannel - LACP between Cisco 3750-X stack and DELL PowerConnect 5448
VolsFan1990
New to this environment, not sure why they setup the network they way they did in the past, but I have replaced our switches DELL PowerConnect 5448 and and unmanaged Linksys 24 port (yeah I know) with Cisco 3750-X stack.
Plan is to re-purpose the DELL PowerConnect (circa 2010) as an ISCI or top of Rack switch and connect our DELL VirtX (DataCenter in a Box) switch/CMS, etc. back to Stack.
The reason - We have existing CAT5e cabling, and Patch Ports are full, that I am I one, not many so trying to get the best practice with no money, equipment (although they did spring for the re-furbished switches).
We have:
AS400 - 2 Ports used, but could be up to 7 if properly fully configured,
DELL Poweredge 2950 (I know old) - 2 ports, plus 1 Console port (not used yet)
DELL Poweredge T310 - 2 ports
APC - SmartUPS 1500 - 1 ports
APC - SmartUPS 3000 - 1 port
1 Printer port (inconsequential 10MBps)
Added DELL VirtX - 8 port switch (2 ports per up to 4 blades - only using 3 so 6 ports) plus 2 redundant CMS ports (should be seperated/segmented traffic).
I digress.
My options were to run all of these connections (I would have to purchase the patch panels, ports, cables) with no budget (typical I know) or
Re-use already ran Patch to Patch to 3750-X stack cables and configure a 4 port Etherchanel/LACP back to switch and plug everything in rack into the Top of Rack switch.
So the questions (You're saying, finally a point):
1.) Is this the best way to accomplish this?
2.) Is a 4 GB Etherchannel enough bandwidth (especially considering before half the network was on a 100 MB unmanaged switch)?
3.) Configuration tips/commands for accomplishing?
4.) If 4, would it be best to configure last two ports (48 Ports switch) on each switch in stack or all into Switch 1 or 2 of the stack?
5.) What is the best way to get some, but not all VLans across this connection?
0 Replies 0
