etherchannel question
roland_costea
Community Member
Hi guys,
How can i make an etherchannel to be backup for another one? what does the "switchport backup" from "interface port-channel" command do?
Also, there is a posibility to make an etherchannel with giga and fast ethernet interfaces?
Thanks and regards!
7 Replies 7
mahmoodmkl
Level 11
Level 11
Not sure about the first one.
U mean to say that using at one end fastethernet and the other end gigabit then its not possible as in a ether-channel the ports needs to be identical.
Mahmood
No...I mean grouping 4 lines into an etherchannel but 2 being fastethernet and 2 giga (same on both ends)
thanks
Roland
In that case u need to create 2 separate channels using the same ports on both the ends.
Mahmood
smothuku
Level 11
Level 11
You can configure etherchannel using 2 or 3 gig or fast ethernet interfaces.
satish
smothuku
Level 11
Level 11
Examples
This example shows how to configure two interfaces as Flex Links:
Switch# configure terminal
Switch(conf)# interface fastethernet0/1
Switch(conf-if)# switchport backup interface fastethernet0/2
Switch(conf-if)# end
This example shows how to configure the Fast Ethernet interface to always preempt the backup:
Switch(conf-if)# switchport backup interface fastethernet0/2 preemption forced
This example shows how to configure the Fast Ethernet interface preemption delay time:
Switch(conf-if)# switchport backup interface fastethernet0/2 preemption delay 150
This example shows how to configure the Fast Ethernet interface as the MMU primary VLAN:
Switch(conf-if)# switchport backup interface fastethernet0/2 mmu primary vlan 1021
The following example shows how to configure preferred VLANs:
Switch(config)# interface gigabitethernet 0/6
Switch(config-if)# switchport backup interface gigabitethernet 0/8 prefer vlan 60,100-120
You can verify your setting by entering the show interfaces switchport backup privileged EXEC command.
In the following example, VLANs 1 to 50, 60, and 100 to 120 are configured on the switch:
Switch(config)# interface gigabitEthernet 0/6
Switch(config-if)# switchport backup interface gigabitEthernet 0/8 prefer vlan 60,100-120
When both interfaces are up, Gi0/8 forwards traffic for VLANs 60 and 100 to 120 and Gi0/6 forwards traffic for VLANs 1 to 50.
Switch# show interfaces switchport backup
Switch Backup Interface Pairs:
Active Interface Backup Interface State
GigabitEthernet0/6 GigabitEthernet0/8 Active Up/Backup Up
Vlans Preferred on Active Interface: 1-50
Vlans Preferred on Backup Interface: 60, 100-120
When a Flex Link interface goes down (LINK_DOWN), VLANs preferred on this interface are moved to the peer interface of the Flex Link pair. In this example, if interface Gi0/6 goes down, Gi0/8 carries all VLANs of the Flex Link pair.
GigabitEthernet0/6 GigabitEthernet0/8 Active Down/Backup Up
When a Flex Link interface comes up, VLANs preferred on this interface are blocked on the peer interface and moved to the forwarding state on the interface that has just come up. In this example, if interface Gi0/6 comes up, VLANs preferred on this interface are blocked on the peer interface Gi0/8 and forwarded on Gi0/6.
Switch# show interfaces switchport backup detail
FastEthernet0/3 FastEthernet0/4 Active Down/Backup Up
Vlans Preferred on Active Interface: 1-2,5-4094
Vlans Preferred on Backup Interface: 3-4
Preemption Mode : off
Bandwidth : 10000 Kbit (Fa0/3), 100000 Kbit (Fa0/4)
Mac Address Move Update Vlan : auto
satish
smothuku
Level 11
Level 11
Example to config etherchannel using gig interfaces...
interface Port-channel5
description ****Ether channel ***
switchport
switchport mode trunk
interface GigabitEthernet1/1
channel-group 5 mode on
interface GigabitEthernet1/2
interface GigabitEthernet2/1
Thanks ,
satish
Thanks guys for answers
Roland
