Etherchannel results unexpected
Patrick McHenry
Level 4
Level 4
I created a 4gig etherchannel from our core/root switch to our distaster recovery switch with no problems. The core/root switch is a 6509 IOS switch and the disaster recovery switch is a 6509 CATos switch. Today I tried to create a redundant 4gig etherchannel from the disaster recovery switch to our other core/backup switch which is a 6509 IOS switch.
This is the output from the show commands of the IOS 6509 core/backup switch:
show interface status:
Gi4/1   Bundle to DR       connected    trunk         full   1000 1000BaseSX
Gi4/2   Bundle to DR       connected    trunk         full   1000 1000BaseSX
Gi4/3   Bundle to DR       connected    trunk         full   1000 1000BaseSX
Gi4/4   Bundle to DR       connected    trunk         full   1000 1000BaseSX
Po220                      notconnect   0             full   auto
show ether summary:
220    Po220(SD)       PAgP      Gi4/1(I)   Gi4/2(I)   Gi4/3(I)   Gi4/4(I) The legend says Stand alone.
sh spanning-tree:
Gi4/1            Desg FWD 4         128.385  P2p
Gi4/2            Desg FWD 4         128.386  P2p
Gi4/3            Desg FWD 4         128.387  P2p
Gi4/4            Desg FWD 4         128.388  P2p
This is the output from the show commands of the CATos 6509 switch:
show port:
5/1  Bundle to OCR      notconnect 1            full  1000 1000BaseSX
5/2  Bundle to OCR      notconnect 1            full  1000 1000BaseSX
5/3  Bundle to OCR      notconnect 1            full  1000 1000BaseSX
5/4  Bundle to OCR      notconnect 1            full  1000 1000BaseSX
show spantree:
5/1                     1    not-connected     4       32 disabled   0
5/2                     1    not-connected     4       32 disabled   0
5/3                     1    not-connected     4       32 disabled   0
5/4                     1    not-connected     4       32 disabled   0
Is this expected behavior, instead of blocking the ports?
glen.grant
   If you are sure you have layer 1 connectivity it will usually tell you in the logs why the channel was not created  if you used negotiated etherchannels .  Seeing it says "notconnect"  you don't even have layer 1 connectivity  at this point .
The IOS switch says connected though? Would it say that if there wasn't a link to the CATos?
Do you think this could be the problem? The mode is set to on with the working channel and nonegotiate for the non-working channel.
Working channel-
3/1      on           dot1q          trunking      1
3/2      on           dot1q          trunking      1
3/3      on           dot1q          trunking      1
3/4      on           dot1q          trunking      1
Not working channel-
5/1      nonegotiate  dot1q          not-trunking  1
5/2      nonegotiate  dot1q          not-trunking  1
5/3      nonegotiate  dot1q          not-trunking  1
5/4      nonegotiate  dot1q          not-trunking  1
  On the not connected side try  doing a "shut then a no shut  on the port channel SVI .  If for some reason the switch put it
into a err-disable state this would bring it back up .  Also verify  that you have the cable where you think they are ,  I would think it would be not connect on both sides if one side was err-disabled.
