etherchannel
dkblee
Level 7
Level 7
hi! i'm trying to connect my blade server's cisco sw module to
the 6509 core by pairing 2 links as a
channel group. below are the related config. The problem is encounter is that i can see the sw neighbor by using sh cdp nei, but i'm not able to ping
the gateway or the management vlan of the blade sw from the 6509 or from the blade sw to other network. I tried to join the vtp domain of the new blade sw to our existing vtp domain, it doesn't get populated into the blade sw as well. what could be the issue here? (native vlan is the same for both side) did i miss out something here? thanks.
6509
interface Port-channel21
switchport
switchport mode trunk
interface GigabitEthernet1/10
description uplink1 to bladechassis
switchport
channel-protocol pagp
channel-group 21 mode desirable
interface GigabitEthernet1/20
switchport
bladechassis sw module
interface GigabitEthernet0/17
description Uplink 1
channel-group 2 mode desirable
interface GigabitEthernet0/18
description Uplink 2
interface Vlan1
10.1.1.1 255.255.255.0
ip-default gateway 10.1.1.254 255.255.255.0
2 Accepted Solutions
Jon Marshall
[email protected]
6509
switchport
switchport
switchport
interface Vlan1
Can you post the output from both the 6500 and the blade chassis
1) sh interface trunk
2) sh etherchannel summary
you don't have a port-channel interface shown in your blade config - did you just miss it out ?
Presumably  10.1.1.254 is the IP address of L3 interface for vlan on the 6500 ?
Jon
glen.grant
  Does the channel show up ?  Show ether summary.   Also keep this in mind those switches are not managed   thru the port channel . They are managed thru a separate  connection to the server management module so if this link is not connected or there is a problem  with that link you won't be able to ping the switches even if the port channel is up and active .   So basically you have your etherchannel connections and a separate connection to the server mgt. module thru which the cisco switches are managed.  I believe it is a config option now to be able to manage them thru the uplinks but by default they are managed thru the mgt. module .  If this is the case then the 6500  would have to have a VLan 1 SVI  configured with the default gateway address for that address space.
5 Replies 5
Reza Sharifi
Can you provide more info:
1- What type of Cisco switches are these?
2-Are they located within a chassis?
3-Are you stacking the switches you are connecting to the 6500?
Reza
the bladechassis's switch is a 4ports cisco sw module
the bladechassis and 6509 are 2 seperate box
no there's only one switch module within that blade server chassis.
thx
Jon Marshall
[email protected]
6509
switchport
switchport
switchport
interface Vlan1
Jon
glen.grant
hi! alll.....thank. the issue has been resolved.
