explanation for unsuccessful attempt to upgrade 9300 switches
wkamil123
I had a situation where stack of two 9300 switches was upgraded from 16.06.03 to 16.06.05 and it couldn't boot up properly.
The upgrade procedure was always the same, place the new image on USB flash and run command request platform software and so on. The upgrade completed sucesfully and the switches was restarted but couldn't boot up new image.
I'm looking for explanation what happened.
Take a look for the content of the packages_conf file. Why rp_boot process was not upgrade to the new version?
boot  rp 0 0   rp_boot         cat9k-rpboot.16.06.03.SPA.pkg
iso   rp 0 0   rp_base         cat9k-rpbase.16.06.05.SPA.pkg
iso   rp 0 0   rp_daemons      cat9k-rpbase.16.06.05.SPA.pkg
iso   rp 0 0   rp_iosd         cat9k-rpbase.16.06.05.SPA.pkg
iso   rp 0 0   rp_security     cat9k-rpbase.16.06.05.SPA.pkg
iso   rp 0 0   rp_webui        cat9k-webui.16.06.05.SPA.pkg
iso   rp 0 0   rp_wlc          cat9k-wlc.16.06.05.SPA.pkg
iso   rp 0 0   srdriver        cat9k-srdriver.16.06.05.SPA.pkg
iso   rp 0 0   guestshell      cat9k-guestshell.16.06.05.SPA.pkg
Kamil
7 Replies 7
balaji.bandi
You have mentioned after upgrade not bootup properly, if you have connected the console.
can you post the logs to have look what is the errors you getting after upgrade ?
BB
Leo Laohoo
I don't see packages.conf file.
as @Leo Laohoo say we didn' t see " packages.conf" and "cat9k_iosxe.16.06.05.SPA.conf", share the logs while you were upgrading the IOS.
BR
Tayyab
*** Please rate all helpful responses and mark solutions***
The packeges.conf file was attached to this message.
I don't have logs now.
The switch restart after Hardware initialization monit
Regards Kamil
Post the complete output to the command "dir flash-1:".
on a side note, did you clean the flash before upgrading ? Not sure if this causes the behavior you describe...
Switch#request platform software package clean switch all
The strange thing was that the last step of upgrade was delete the old soft
packages. I didn't see that on 3850 platform before.
The next strange thing it was that ROMMON shows the old packeges, new soft
packages and bin image are in flash switch.
The command that you provide I run at the end and on one switch remove all
apckages and bin image. On second switch remove only the old packeges.
