05-09-2016 01:57 PM - edited 03-08-2019 05:40 AM
Hi all,
I have my Nexus 5672up and my Fex 2348UPQ, and when I do my basic fex config and I do a show int brief the links are always down.
In the logs I get this output
command failed: port not compatible [port mode]
Nx5k(config-if-range)# 2016 May 9 20:39:15
Nx5k %ETH_PORT_CHANNEL-3-COMPAT_CHECK_FAILURE: port mode is not compatible
channel-group 100
command failed: port not compatible [Members should have same fex config]
Nx5k(config-if-range)# 2016 May 9 20:40:55
Nx5k %ETH_PORT_CHANNEL-3-COMPAT_CHECK_FAILURE: Members should have same fex config is not compatible
I tryed with the 10gb sfp and wit the fet-10g also and have the same issue.
thanks.!
05-09-2016 04:31 PM
Are the physical ports up?
What is port number you are trying to add to the Po?
What is the output of "sh ver"?
05-09-2016 05:17 PM
Hello Reza,
The version is 7.0.1.
What I found is that with the
Thanks.
