flash and bootflash
sharma16031981
Level 3
Level 3
Hi All,
Could any one please help !!!
1.what is flash and bootflash
2.can we have both in same L3 switch.
3. why some models have only flash or bootflash and what it the significance of both.
Thanks for any help.
sharma16031981
Level 3
Level 3
Friends please help !!!
These memory devices are included in the matrix:
  • DRAM/SDRAM—Memory used to perform the CatOS or IOS system images.
  • NVRAM—Memory used to store start-up configuration file (nvram:).
  • OnBoard Flash—Memory used to hold system images for booting (bootdisk: or bootflash: or flash:).
  • Removable Flash—Memory which can be removed from the system which typically holds system images (slot0: or disk0: or disk1:).
Essentially the difference is just naming convention between flash and bootflash (depending on model).
Ref:
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00801a5d58.shtml
HTH,
Ian
