Flat network layer 2 issues
howithink
Level 3
Level 3
I need help. We are in the process of changing a large  L2 network. Everything terminates into a single small FW. The IP range is 172.16.10.0/22 so the end of the port configured on the FW is 172.16.10.1/22. This is where everything terminates.
Now we want to remove this function from the FW and introduce a L3 device with a vlan which i created called VLan4 and the ip address i assigned to it is 172.16.10.1/22. Also made necessary route changes to send traffic to FW and out.
I was hoping that when we unplug the cable from the FW and into the L3 that everything will work, but it is not. I am getting Arp incomplete. It looks like behind the L3 there are other devices (hubs/switches) and when i do show cdp neigh, my port on L3 shows as connected to 2 different devices.
What am i doing wrong?
15 Replies 15
If all the Switches are L2, then you need to create an SVI with Vlan 1 and allocate FW IP address to that SVI ( and keep that in shutdown mode)
follow below steps on Switch :
config t
interface vlan 1
ip address 172.16.10.1/22
shutdown
When the maintenance window agreed, remove the FW Cable, from Swtich
in the switch
config t
interface vlan 1
no shutdown
ping from device and advise.
once this is success, you need to create FW different IP address and accordingly for internet and NATiing part.
Hope this steps helps.
BB
