Force a Cisco Switch to use SSH 2
thestagman
Anyone any ideas on how to force a IOS switch (cat 3750) to only use SSH ver 2 ?
Mike
thestagman
Its okay, I have just learned the Cisco IOS Software only supports SSH Ver 1.
Some IOS supports version 2. Feature Navigator should help.
1721#config t
Enter configuration commands, one per line. End with CNTL/Z.
1721(config)#ip ssh version ?
<1-2> Protocol version
1721(config)#end
1721#sh ip ssh
SSH Enabled - version 2.0
Authentication timeout: 120 secs; Authentication retries: 3
1721#
ajagadee
Mike,
3750's does support SSHv2. If I remember correctly, 12.1(19)EA1 and higher should support SSHv2.
What code are you currently running on the 3750. Also, make sure that you have the right feature set.
I hope it helps.
Arul
** Please rate all helpful posts **
SSH v2 support is included in all the new versions.
you can enable it by the command
ip ssh version 2
Narayan
