Force failover of an HSRP active without interruption
ManuelCasal1985
If force the failover with hsrp, would it be an interruption on that subnet?.
mikegrous
Level 3
Level 3
If preempt is on
And you simply change the priority from lower to higher on the standby switch. There should be no traffic inturuption.
---switch 1----
interface Vlan10
standby 1 ip 10.129.10.1
standby 1 priority 101
standby 1 preempt
---switch 2----
interface Vlan10
standby 1 priority 110
standby 1 preempt
Switch 2 will be active.  Simply go on switch 1 and enter
interface Vlan10
standby 1 priority 120
It will be come active
Is their a command for failover via HSRP?
You have to enable preempt on both cores. 1 core will be hsrp active due to its higher priority. If you want the other core active simplly make that priority higher.
Thank you, sir!
