Forward Broadcast
hs08
I have subnet like this :
  • My pc under vlan 100 (192.168.100.0/24)
  • My NAS under vlan 150 (192.168.150.0/24)
Actually when the nas and pc located under same subnet, I can discovery the nas from my laptop using vendor utility, but can't discover when the pc and nas in different subnet. So can we forward broadcast for my pc can discover the nas in different subnet?
14 Replies 14
Torbjørn
Are you sure it is utilizing broadcast, and not multicast? If it is multicast you can enable multicast routing on your gateway to achieve discoverability in other subnets.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
try use
IP helper under the VLAN 100 toward the broadcast IP of VLAN 150 subnet
MHM
You will also need to enter the following config on your gateway interface for VLAN 150:
ip directed-broadcast
thanks for remember me
MHM
hs08
hello,
Here my config
interface Vlan100
ip address 192.168.100.0 255.255.255.0
ip helper-address 192.168.150.255
interface Vlan150
ip address 192.168.150.0 255.255.255.0
But seem this is not work, the utility still can't find the NAS
We need more information about this environment, especially what protocol the vendor utility uses to discover the server.
ip helper-address forwards certain UDP protocols. It is likely that the vendor utility uses a protocol that is not one of these. If you know the protocol (and if it is a UDP protocol) then you can use the ip forward-protocol command to enable forwarding of this protocol.
Rick
If i check the apps using UDP port 9999
BTW, might be helpful if you had a packet capture of the application traffic in both directions.
ip forward-protocol udp 9999
This need also
MHM
already add the command but still not discovered.
I run lab for  DHCP and it work
in NAS can you ping VLAN 100 SVI ?
MHM
MHM correctly suggests the need to configure ip forward-protocol. The OP responds "already add" but does not tell us whether this is added under vlan 100 or 150. It needs to be under the receiving vlan (150).
Rick
This command in global mode not under interface.
MHM
MHM
You are correct. Thanks for pointing out my mistake. I was thinking of directed-broadcast, which is an interface command, and should not have indicated that for forward-protocol.
Rick
