GLC-BX-D in C9300 with C9300-NM-8X
Akreman21
HI. we´re having problems with this SFP GLC-BX-D.
This GLC-BX-D is working perfectly if it´s inserted in this device:
C9300-24T  Version 16.9.4 with C9300-NM-8X  VID: V03 (it´s a stack)
But, If I insert it on this device, I dont see it via "sh inventory" :
C9300-24UX Version  16.12.4 with C9300-NM-8X VID: V03 (it´s a stack)
I see this message:
%PLATFORM_PM-6-MODULE_ERRDISABLE: The inserted SFP module with interface name Te2/x/x
I have done shut and no shut command...and the problems goes on.
At the opposite side , I keep the same type of module (GLC-BX-U).
I´ve checked this matrix and I see the module GLC-BX-D is valid for my equipment (
https://tmgmatrix.cisco.com/?si=C9300-NM-8X )
Could you hellp me whith this problem ???
Thanks in advance
Leo Laohoo
Raise a TAC Case and get them to verify if this is CSCvx25489.
IMPORTANT WARNING:  Avoid using 16.12.X.
balaji.bandi
is this cisco brand SFP ?  Try to remve the SFP and just add speed 1000 and connect ?
BB
marce1000
 - A number of bug reports which could be applicable : https://bst.cloudapps.cisco.com/bugsearch?pf=prdNm&kw=PLATFORM_PM-6-MODULE_ERRDISABLE&bt=custV&sb=anfr&prdNam=Cisco%20Catalyst%209300%20Series%20Switches
 M.
hemmerling
Sounds like a bug, but we've seen the same thing with different Cisco branded SFPs before, maybe try the old quick-fix commands and see it if works.
service unsupported-transceiver
no errdisable detect cause gbic-invalid
