Data+Voice vlan configured on a switchport
Marc_AMI1
Hi guys,
I have a Cisco switch configured with two vlans :
VLAN 10 : Voice
VLAN 20 : DATA
My switch ports are configured as shown below :
interface GigabitEthernet1/0/X
switchport mode access
switchport access vlan 20
switchport voice vlan 10.
When I connect : Switchport-----IpPhone -----PC  : it's working fine.
My Questions :
Can I directly connect the PC  to that switchports ?
Will the PC fall in the DATA VLAN ?
How does the switch detect if it's a PC or Phone to provide the right vlan ?
Thanks very much
hemmerling
I don't remember the exact mechanism of how the phone goes into the voice VLAN (possibly CDP from the phone), but the computer will only be in the data VLAN if plugged directly to the switchport. I think the tagged voice VLAN traffic is available to the computer's NIC (so a promiscuous mode NIC and Wireshark can likely see voice VLAN broadcast traffic).
Reza Sharifi
Yes
Yes
The switch uses CDP to instruct the phone to send voice traffic:
see link page-page-14-2
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_40_se/configuration/guide/scg/swvoip.pdf
balaji.bandi
BB - yes you can as per the config.
BB - yes PC get Data vlan IP address ( from DHCP)
Cisco has good document which explains :
BB
Joseph W. Doherty
"Can I directly connect the PC to that switchports ? "
As already noted by other posters, yes you can.
"Will the PC fall in the DATA VLAN ?"
Normally, yes.  The DATA VLAN is untagged and PCs, almost always, don't tag their frames.  However, if PC tags its frames, which again is possible, its traffic might end up on Voice VLAN, or not work at all.
"How does the switch detect if it's a PC or Phone to provide the right vlan ?"
I recall, the switch, itself, doesn't (nor care).  It's up to the connecting device to use untagged or (correctly) tagged frames.
As the other posters have noted, a device, especially Cisco VoIP phones, can determine (i.e. using CDP) there's a voice VLAN and the VLAN being used for it.  The device can then, dynamically, tag its frames to access that VLAN.
Non-Cisco VoIP phone, if they don't use CDP, might need to be "hard coded" for what VLAN to use for their voice traffic.  Some non-Cisco phones, might first get a DHCP packet on the DATA VLAN, which contains a DHCP option for what VLAN to be used for voice traffic, upon which, the VoIP phone will dynamically start using frames tagged for that VLAN.
BTW, you can have "Switchport-----IpPhone -----PC " also working fine w/o using a voice VLAN.  A voice VLAN, shared with a DATA VLAN, on the same port, allows "logical" control of traffic on their respective VLANs, but remember, the physical port, and its capacity, is still shared between the VLANs.
