help using CMS
gserghiou
Community Member
Hi all,
I have been`studying´about the 2950 switch that we have here at work, and found out that i can connect to a graphical manager (CMS) using http.
I have given the switch an IP on vlan1 and then issued the NO SHUTDOWN to the vlan. my ip works, as i can telne to the switch. However when i try to access CMD i get no response for ages.
I believe that my switch hardware-firmware supports this.
Here is a sample output of my SHOW VERSION :
<b>
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(11)EA1, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Wed 28-Aug-02 10:25 by antonino
Image text-base: 0x80010000, data-base: 0x80528000
ROM: Bootstrap program is CALHOUN boot loader
Switch uptime is 4 weeks, 4 days, 16 hours, 48 minutes
System image file is "flash:/c2950-i6q4l2-mz.121-11.EA1.bin"
cisco WS-C2950-24 (RC32300) processor (revision G0) with 20402K bytes of memory.
Processor board ID FOC0644Y1RN
Last reset from system-reset
Running Standard Image
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0B:5F:15:4D:00
Motherboard assembly number: 73-5781-11
Power supply part number: 34-0965-01
</b>
Is there another graphical manager i can use?
Can someone please shed some light on this?
Thank you,
George
Hi george...
ip http server is the command which enables http access to your switch from the PC.. what is the version of the software that you are using ? you need to have java plugins for some IOS.. you should also have the required hardware/software on the PC from which you are trying...
The following document gives you a complete understanding of the requirements/troubleshooting when using CMS...
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a0080094709.shtml#topic2
hope this helps.. all the best.. rate replies if found useful...
sachinraja
Level 11
Level 11
Hi george...
Are you able to ping the CMS server from the PC you are trying to access ?? Is the CMS server and the PC in the same network ?
well.. you can use http access for the switch, by enabing http x.x.x.x (ip address of the host) on the switch, but i always advice you to configure it on the CLI..
anyway, let us know the above details and give us more information on the connectivity..
All the best...
Hi again,
I hope i dont sound stupid,
First of all, i can tell you that i am able to ping the switch and get the replies. We are both on the same subnet. My address: 10.51.12.31/24 and the switch is 10.51.12.11/24 .
When you say CMS server you mean the switch i want to connect to....????
You also mention enabling http x.x.x.x of the host on the switch.
Is there a command i need to configure for this and what would this be ???
I am showing here the basic configuration i have so far on the switch, to make troubleshootign easier.
interface Vlan1
ip address 10.51.12.11 255.255.255.0
no ip route-cache
ip http server
snmp-server engineID local server engine id here
snmp-server community my password here
line con 0
line vty 0 4
password my password here
login
line vty 5 15
login
end
The rest of the configuration is just the interfaces which have nothing configured on them.
Thanks again,
George
Hi george...
Thanks Sachin,
My problem was th eproxy setting in the Browser (IE)
I left it on, and just bypassed the switch address.
Thanks for the help,
I will be back with more questions.
Thanks once more,
George
