11-06-2006 06:04 AM - edited 03-05-2019 12:38 PM
Does anyone know if this bug affects 6500's running IOS or is it only CatOS
11-06-2006 06:35 AM
Hi ,
I've checked the Bug and it affets 6500 CatOS , not sure about IOS.
It is not resolved and there is no work around.It is closed because they are suspecting it as a Spanning Tree issue..The problem can be seen on several switches that have the same type of sup HW
and SW.
Hope it helps you.
satish
11-06-2006 06:37 AM
since the bug toolkit does not specify any other OS than catOS 7.3(2), it would suggest that this has not been seen in the IOS for that device.
this bug actually has very little version info compared to what most bugs do.
(it doesn't even tell you what version it is fixed in, although the status of the bug is 'closed')
