05-30-2012 07:53 AM - edited 03-07-2019 06:59 AM
I have a process whick take all the CPU on two differents Stack of WS-C3750G in version 12.2.53(SE2):
XFRPALSN02R#sh proc cpu sorted
CPU utilization for five seconds: 97%/3%; one minute: 95%; five minutes: 95%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
307 5450059 4167397 1307 86.74% 83.63% 83.35% 0 hulc nrgyz PD di
CPU utilization for five seconds: 96%/3%; one minute: 96%; five minutes: 96%
307 7779608 5947379 1308 86.26% 85.75% 85.30% 0 hulc nrgyz PD di
Can you give me some explanations about this process.
05-30-2012 08:18 AM
05-30-2012 08:24 AM
This is EnergyWise PD discovery process. It looks like you are hitting the following bug:
CSCth62705 EnergyWise PD discovery process caused CPU high, fixed in 12.2(58)SE2
Symptom:
The switch experiences high CPU usage when new domain members or EnergyWise capable endpoints with a different EnergyWise domain are added to a existing domain and EtherChannel is configured.
Conditions:
A combination of cross domain traffic introduced via a endpoint or domain member and Etherchannel configuration between a access and distribution switch that has EnergyWise enabled at both ends is necessary to reproduce the problem.
Workaround:
The workaround would be to disable the port channel in the case where the high CPU usage is seen.
Here you can read more information on EnergyWise features:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps10195/white_paper_c11-568212.pdf
http://www.cisco.com/en/US/docs/switches/lan/energywise/phase1/ios/configuration/guide/configex.html
Kind Regards,
Ivan
**Please grade this post if you find it useful.
