Home Lab - How to setup simple VLAN and have them all communicate with each other and the internet
zvaligura
I'm setting up a simple homelab as I learn CCNA using a 3560G-48P.  I have setup a vlan 20 and put 16 ports on it.  The host is my PS4 since its easy to see network info.  I setup a dhcp pool of 10.0.5.0 /24 and assigned it to vlan 20.  on the switch I can ping 10.0.5.2 (the ip assigned to the PS4) with all packets.  However, on the PS4 it is not able to access the internet through the router at 192.168.1.1.  I setup RIPv2 and still no luck.
To further test I put in another 3560 switch on the network and trunked it to the main switch.  I setup ripv2 and ran show ip route but 10.0.5.0/24 didn't show up.  I tried pinging 10.0.5.2 from here and it didn't go through.
Could I be missing something simple here?
leinad427
What is your setup?
1)Router>SW>ps4?
or do you have
2)ISP_ROUTER>Cisco_router>SW>ps4?
if you have option 2 are you able to ping a public dns like 8.8.8.8?
does your SW have a default gateway assigned?
post a runn config from both Router and Switch
It's
ISP Router (NVG468MQ) -> Cisco 3560G -> PS4
ISP Router (NVG468MQ) -> Cisco 3560G -> Cisco 3560G
So, after messing with this I got it working and connected to the internet in the 10.0.2.0 subnet.  Afterwards I took out each thing I tried and if it didn't break the connection I left it out.  If it did break the connection I put it back in.
I found the following:
-in the IP DHCP Pool I needed to have the:
DNS-SERVER 192.168.1.1
DEFAULT ROUTER 10.0.2.1
-On the ISP routers I setup a static route for 10.0.0.0/8 to 192.168.1.2 (IP of 3560G).
So now my question is why the RIPv2 isn't updating the Router AND the Lab3560G I have connected.  I was hoping I wouldn't have to setup a static route if I setup RIPv2.
Pictures of the NVG468MQ ISP Router
3560G Core Config:
version 15.0
no service pad
service password-encryption
service sequence-numbers
hostname 3560-CORE
boot-start-marker
boot-end-marker
logging userinfo
logging buffered warnings
enable secret 5
enable password 7
no aaa new-model
clock timezone CST -6 0
clock summer-time CDT recurring
system mtu routing 1500
ip routing
ip domain-name ex
ip dhcp pool HomeAuto
 import all
 network 10.0.5.0 255.255.255.0
 default-router 10.0.5.1
 dns-server 192.168.1.1
ip dhcp pool Data
 import all
 network 10.0.2.0 255.255.255.0
 default-router 10.0.2.1
ip device tracking
crypto pki trustpoint TP-self-signed-1897608192
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1897608192
 revocation-check none
 rsakeypair TP-self-signed-1897608192
crypto pki certificate chain TP-self-signed-1897608192
 certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
spanning-tree mode pvst
vlan internal allocation policy ascending
lldp run
interface GigabitEthernet0/1
 switchport mode dynamic desirable
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
 shutdown
interface GigabitEthernet0/8
 shutdown
interface GigabitEthernet0/9
 shutdown
interface GigabitEthernet0/10
 shutdown
interface GigabitEthernet0/11
 shutdown
interface GigabitEthernet0/12
 shutdown
interface GigabitEthernet0/13
 shutdown
interface GigabitEthernet0/14
 shutdown
interface GigabitEthernet0/15
 shutdown
interface GigabitEthernet0/16
 shutdown
interface GigabitEthernet0/17
 switchport mode access
 switchport port-security mac-address sticky
interface GigabitEthernet0/18
interface GigabitEthernet0/19
 shutdown
interface GigabitEthernet0/20
interface GigabitEthernet0/21
 shutdown
interface GigabitEthernet0/22
interface GigabitEthernet0/23
 shutdown
interface GigabitEthernet0/24
interface GigabitEthernet0/25
 shutdown
interface GigabitEthernet0/26
interface GigabitEthernet0/27
 shutdown
interface GigabitEthernet0/28
interface GigabitEthernet0/29
 shutdown
interface GigabitEthernet0/30
interface GigabitEthernet0/31
 shutdown
interface GigabitEthernet0/32
interface GigabitEthernet0/33
 switchport access vlan 20
 shutdown
interface GigabitEthernet0/34
interface GigabitEthernet0/35
 shutdown
interface GigabitEthernet0/36
interface GigabitEthernet0/37
 shutdown
interface GigabitEthernet0/38
interface GigabitEthernet0/39
 shutdown
interface GigabitEthernet0/40
interface GigabitEthernet0/41
 shutdown
interface GigabitEthernet0/42
interface GigabitEthernet0/43
 shutdown
interface GigabitEthernet0/44
interface GigabitEthernet0/45
 shutdown
interface GigabitEthernet0/46
interface GigabitEthernet0/47
 shutdown
interface GigabitEthernet0/48
interface GigabitEthernet0/49
 shutdown
interface GigabitEthernet0/50
 shutdown
interface GigabitEthernet0/51
 shutdown
interface GigabitEthernet0/52
 switchport access vlan 5
 shutdown
interface Vlan1
 ip address dhcp
 ip rip send version 2
 ip rip receive version 2
interface Vlan2
 no ip address
interface Vlan5
 no ip address
interface Vlan10
 ip address pool HomeAuto
interface Vlan20
 ip address pool Data
router rip
 version 2
 network 10.0.0.0
 network 192.168.1.0
 no auto-summary
ip http server
ip http secure-server
tftp-server flash:
line con 0
line vty 0 4
line vty 5 15
ntp master
ntp server 132.163.97.1
ntp server 132.163.96.1 prefer
ntp server 129.6.15.28
end
Deepak Kumar
Check the default route on your router and configure the RIP with a command "ip default-network" to generate the default route information.
If the default route is correctly configured then check your NAT configuration.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
