Host flapping between ports
vishalpatil86
Level 7
Level 7
Dear All,
Two days back my entire network was behaving in unusual ways.
When is connect to core switc(4506e) through console, i found following -
00:06:51: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/3 and port Gi4/2
00:06:52: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/3 and port Gi4/2
00:06:54: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/3 and port Gi4/2
00:06:56: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/3 and port Gi4/2
00:06:58: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/2 and port Gi4/3
00:07:00: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/2 and port Gi4/3
00:07:02: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/3 and port Gi4/2
00:07:04: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/2 and port Gi4/3
00:07:06: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/3 and port Gi4/2
00:07:08: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/3 and port Gi4/2
00:07:10: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/2 and port Gi4/3
00:07:12: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/2 and port Gi4/3
00:07:14: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/3 and port Gi4/2
00:07:17: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/2 and port Gi4/3
00:07:18: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/2 and port Gi4/3
00:07:20: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/3 and port Gi4/2
00:07:22: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/2 and port Gi4/3
00:07:24: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/3 and port Gi4/2
00:07:27: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/2 and port Gi4/3
00:07:28: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/3 and port Gi4/2
00:07:30: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/3 and port Gi4/2
00:07:32: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/3 and port Gi4/2
00:07:34: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/2 and port Gi4/3
00:07:36: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/2 and port Gi4/3
00:07:38: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/2 and port Gi4/3
00:07:41: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/2 and port Gi4/3
00:07:42: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/3 and port Gi4/2
00:07:44: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/3 and port Gi4/2 00:06:51: %C4K_EBM-4-HOSTFLAPPING: Host 02:26:9E:DA:E9:C3 in vlan 1000 is flapping between port Gi4/3 and port Gi4/2
Please advise. Also when i try to find mac ID 02:26:9E:DA:E9:C3, i couldn't find it in mac address finder
14 Replies 14
Leo Laohoo
Hmmmm ... That's not a VM, is it?
I have the same issue, my machine on the flapping ports is a hyper v with several vm's.  So is then normal behavior?
Thank you
Raju Sekharan
Try to trace the mac using the command
show mac-adress address 02:26:9E:DA:E9:C3
Where is gi 4/3 and 4/2 connected?
Raju
CHAD REID
Visitor
vishalpatil86, is either end of the link configured as a port-channel? It sounds like one end is configured as such and the other isn't. This could cause a spanning-tree loop and many other nasty things.
michal.adam
Community Member
This is maybe spanning-tree loop. Check these ports.
Milan Rai
Level 3
Level 3
Hey visal at first go back to the day when it was working fine...........And just trying to rembember if you have done any changes on the network or i mean to say if you have plugged in any new cables on the switch. .....According to your log its not only the problem of one port so......eventually its being changed that means.....you are having loop on the network.......Plz trying to know if STP is working properly or not........And if you have HSRP configured......dont forget the check the status of stand by IP that matters a lot.......Good Luck
I am curious why doesnt that MAC address appear on OUI finder?
http://www.wireshark.org/tools/oui-lookup.html
Actually plz try to find out....if you have 2 devices with the same MAC address...........Sometimes.....low end devices are having same mac due to which eventually ..........from port gig 4/3 and 4/2 they are trying to access the network so there if flapping...occuring........
Better you trace each port....... with sh cdp neighbour ..........
If possible remove one cable from either 4/3 or 4/2 and check if the problem exist...........
About the mac address will you plz check out in the neighbour device????
I got it you can  try find only 00-1C-23
Is it Dell
Also check the SFP & Fiber port & Physical cbale.
We have faced the similar issue & found SFP & Fiber patch cord faulty
Rolf Fischer
Level 11
Level 11
The first Byte of the MAC address ("02") tells you that the U/L-Bit is set to "local", that means it's not the Burned-In Address of the NIC but locally administered (http://en.wikipedia.org/wiki/File:MAC-48_Address.svg).
Most probably it's a virtual or shared address of a NIC-Team or something like that.
What devices are connected to Gi4/2 adn Gi4/3?
What about an ARP-Entry for 02:26:9E:DA:E9:C3?
How many and what kind of devices do you have inVLAN 1000?
Rolf
Thank you fischer.rolf. and Mike.
I thought I might help by saying what make/model the device was, I have never seen a full MAC not listed in the OUI finder.  But as was suggested, I took off the last 3 octets, and got it.  I wonder if milkmen learned stuff every day like we do
muna kamel
Frequent Visitor
Frequent Visitor
I have also this message sunddenly on switch :
a58.d4fc in vlan 810 is flapping between port Gi1/0/1 and port Gi1/0/8
02:34:23: %SW_MATM-4-MACFLAP_NOTIF: Host 0023.ea5a.fcfc in vlan 810 is flapping between port Gi1/0/8 and port Gi2/0/1.
JustinMBeeker
Community Member
Make sure you have vlan 1000 created on the switch, I just experienced this and fixed it by creating the vlan I missed.
