How setup basic IP routing on 3725 router.
NB243_243
Community Member
Below is the router and interface configuration of two 3725 routers. The problem is, I'm not able to ping PC connected to each router (PC1 connected to Router_01 and PC2 connected to Router_02, (Router_01 directly connected to Router_02). I'm able to ping each router's port but not the PC beyond each of the routers. As an added note each PC is connected to its respective router through a 2950 switch. I can ping from PC to PC when I remove the routers and just use the switch so I know the swithes are pass the packets.
What am I missing?...
Thanks in advance,
NB243
Router #1:
no aaa new-model
ip subnet-zero
ip cef
ip multicast-routing
no ftp-server write-enable
interface FastEthernet0/0
ip address 148.x.0.x.255.0.0
ip information-reply
ip directed-broadcast
ip rip advertise 59
ip rip send version 1
ip rip receive version 1
duplex auto
speed auto
interface FastEthernet0/1
ip rip advertise 59
duplex auto
speed auto
router rip
network 148.33.0.0
network 148.34.0.0
network 148.35.0.0
network 148.36.0.0
neighbor 148.x.0.2
ip classless
ip http server
line con 0
line aux 0
line vty 0 4
end
Router #2:
no aaa new-model
ip subnet-zero
ip cef
ip rip advertise 59
duplex auto
speed auto
ip rip advertise 59
duplex auto
speed auto
interface FastEthernet2/0
ip rip advertise 59
duplex auto
speed auto
router rip
version 1
network 148.33.0.0
network 148.34.0.0
network 148.35.0.0
network 148.36.0.0
neighbor 148.x.0.1
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
end
Typical interface configuration:
Router_02#show ip interface fast 0/0
FastEthernet0/0 is up, line protocol is up
Internet address is 148.x.0.1/16
Broadcast address is 255.255.255.255
Address determined by setup command
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is enabled
Multicast reserved groups joined: 224.0.0.9
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Local Proxy ARP is disabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is enabled
IP fast switching on the same interface is disabled
IP Flow switching is disabled
IP CEF switching is enabled
IP CEF Fast switching turbo vector
IP multicast fast switching is enabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast, CEF
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Policy routing is disabled
Network address translation is disabled
WCCP Redirect outbound is disabled
WCCP Redirect inbound is disabled
WCCP Redirect exclude is disabled
BGP Policy Mapping is disabled
12 Replies 12
Georg Pauwen
make sure you router 1 is running RIP version 1 as well (as is your router 2). Also, what cable are you using between your 2950(s) and your router(s) ? Make sure you are using straight cables, not cross cables. And lst but not least, check the default gateways on your client computers, and make sure they match the IP addresses of your respective router interfaces...
GP
Hello GP.
I have done all that... As I have indicated in my post, I can ping the router ports from each PC and I have the gateway configured on each PC to match the respective connected router interfaces. Also The cables are correct. I can also ping the neighboring router (using the console connection and submiting commands directly from each router, but again, I'm not able to ping the PC connected to the other interface through that respective router). Also note the configuration info I supplied... It indicates that I have configured RIP version 1 on each router...
So what am I missing?...
NB243
From routerA:
Do an extended ping (ping ip )
make sure that the target ip is interface or gateway of PC in router B and source is the interface of the gateway from PC in router A. are the pings going through? If not, there the issue is routing. On both router inverstigate the result of show ip route:
from Router A:
show ip route
From router B:
show ip route
From both of this show ip route I am sure you will find which router is pointing to the wrong interface. If all is working per output, post all the output requested here. Let us take a look at it.
Please rate this post if it helps.
From the description of the synptoms in the original post I thought that the most likely problem was that the default gateway in one or both PCs was not set correctly. But the original poster states that they are set correctly.
From the configs it looks like the routers should talk and should share routes. But I agree with Roberto that it sounds like the routers may not have correct routing information about the remote destinations. It would be very helpful to see the output of show ip route from both routers. I think it would also be helpful to see the output of show cdp neighbor detail from both routers.
Rick
Rick
Hello Rick, and others.
I've made some changes.
(Focusing on Router_02, if resolved then I can fix Router_01 too).
Here is current configuration and output:
FastEthernet0/0=148.33.0.1
FastEthernet0/1=148.35.0.2
FastEthernet2/0=148.36.0.1
PC#1=148.35.254.1 connected via switch into interface 0/1.
PC#2=148.36.200.200 connected directly into interface 2/0.
I can ping all interfaces on router from the router's CLI.
I can ping interface 0/1 from PC#1.
Cannot ping interfaces 0/0 & 2/0 from PC#1.
I can ping PC#2 directly from the router's CLI.
I cannot ping from PC#1 -> PC#2 or PC#2 -> PC#1.
Also I cannot ping interfaces 0/0 & 0/1 from PC#2.
PC#1 Command Prompt Output
> ping 148.35.0.2
Pinging 148.35.0.2 with 32 bytes of data:
Reply from 148.35.0.2: bytes=32 time<1ms TTL=255
> ping 148.33.0.1
Pinging 148.33.0.1 with 32 bytes of data:
Request timed out.
> ping 148.36.0.1
Pinging 148.36.0.1 with 32 bytes of data:
Request timed out.
Router_02 CLI Output
Router_02#show ip interface brief
FastEthernet0/0 148.33.0.1 YES manual up up
FastEthernet0/1 148.35.0.2 YES manual up up
FastEthernet2/0 148.36.0.1 YES manual up up
Router_02#show ip route
Gateway of last resort is not set
S 148.34.0.0/16 [1/0] via 148.35.0.1
C 148.35.0.0/16 is directly connected, FastEthernet0/1
C 148.33.0.0/16 is directly connected, FastEthernet0/0
C 148.36.0.0/16 is directly connected, FastEthernet2/0
Router_02#ping 148.36.200.200
Sending 5, 100-byte ICMP Echos to 148.36.200.200, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Router_02#ping 148.35.254.1
Sending 5, 100-byte ICMP Echos to 148.35.254.1, timeout is 2 seconds:
Router_02#show arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 148.35.254.1 18 0011.433b.c752 ARPA FastEthernet0/1
Internet 148.36.200.200 7 0010.a47a.021d ARPA FastEthernet2/0
Internet 148.36.0.1 - 0012.013d.60a1 ARPA FastEthernet2/0
Internet 148.33.0.1 - 0012.013d.6080 ARPA FastEthernet0/0
Internet 148.35.0.2 - 0012.013d.6081 ARPA FastEthernet0/1
Internet 148.35.0.1 0 Incomplete ARPA
Router_02#
no aaa new-model
ip subnet-zero
ip cef
ip multicast multipath
duplex auto
speed auto
duplex auto
speed auto
duplex auto
speed auto
router rip
network 148.33.0.0
network 148.34.0.0
network 148.35.0.0
network 148.36.0.0
neighbor 148.35.0.1
ip classless
ip route 148.33.0.0 255.255.0.0 148.35.0.1 permanent
ip route 148.34.0.0 255.255.0.0 148.35.0.1 permanent
ip route 148.35.0.0 255.255.0.0 148.35.0.1 permanent
ip route 148.36.0.0 255.255.0.0 148.35.0.1 permanent
no ip http server
line con 0
line aux 0
line vty 0 4
end
I think your strategy of troubleshooting by simplifying the environment is good. The information that you have proveded in this post is helpful.
I think that it is especially helpful to see the output from ping that demonstrates that the router can communicate directly with both PCs. And I think the output from the ARP table showing successful layer 2 connectivity to both PCs is successful is also helpful.
I would suggest a follow up test to your ping test. When you ping to PC#1 at 148.35.254.1 it uses as source address the interface address of interface 0/1 and it is successful. Now I suggest that you do an extended ping. In the extended ping specify the destination as PC address 148.35.254.1 and specify the source address (using the extended commands in extended ping) as interface 2/0.
I suspect that the extended ping will probably fail. If the standard ping succeeds then it demonstrates that the router has a route to the PC. If the extended ping fails, and we know that the router has a route to the PC, then the failed extended ping probably means that the PC does not have a route to the address of interface 2/0. And that probably indicates a problem with the configuration of default gateway in the PC. Perhaps you could do an ipconfig on the PC and post the output.
Rick
Rick
can you also post the output of 'route print' from your PC2 ?
GNT
Looking at the original config's
On router 1 there are only two interfaces but four networks configured under RIP.
On router 2 there are only three interfaces but four networks configured under RIP.
Also, the networks are the same on each router RIP process. I would think that the only overlap would be the network connecting the two routers, 148.35.0.0
I would clean up the RIP config then see how things work.
router 1
router rip
network 148.34.0.0
network 148.35.0.0
neighbor 148.35.0.2
router 2
router rip
network 148.33.0.0
network 148.35.0.0
network 148.36.0.0
neighbor 148.35.0.1
Hello Sean Conway and others that have sounded in on this problem...
I have been digging into this problem all along then I was out of town for a while. I never got the original computers to talk properly across the routers and I gave up on them due to time constraints... BUT! When I connected the computers that would ultimately be doing the work 'so-to-speak' they presented almost the same symptoms. I found out that they were cloned disk images and there are applications that run on these computers that have IP address embedded in them. Anyway what tipped me off was one-way intermittent ping success. I change the embedded IP address to match the Windows NIC address configuration and gateway and now they talk...
Also Sean the 3rd address in RIP on router #1 is the neighboring router's port address and the 4th address in RIP on router #2 is the neighboring router's port address. Notice they are preceded with the word 'neighbor' and not 'network'.
Thank you all for helping me solve this problem... Maybe, if I have the time I'll hook up the original two computers back up to the routers and figure out why they would not ping each other properly and give feedback on what I found...
Later,
NB_243
Hello Sean.
OOPS! I didn't look at my last post, I just looked at yours and I didn't realize that you had posted a correction to what I had posted.
I had the network address for all routes on each router's RIP configuration. You're right I did have more network addresses than the number of interfaces on each router... Excuse my ignorance... How do the extra network addresses affect the router's performance in forwarding/passing routes for the way I have things setup?
Thank you,
NB_243
Sorry for the double posting of this message... When I did a reload/hard refresh of the page it posted again.
Hello Sean.
Thank you,
NB_243
Having extra network statements is ineffecient. They do no good. But they also do no harm. There is no impact from having extra network statements beyond the impact of making the configuration file slightly larger.
The basic principle of network statements for Interior Routing Protocols (RIP, OSPF, EIGRP) is that you should have network statements for the locally connected interface/network that you want to participate in the routing protocol. There is no benefit in having network statements for networks that are remote to the router.
Rick
Rick
