Switching
Labels
Welcome to the Cisco Community Ask Me Anything conversation. Submit your questions from Monday, February 2, 2026, through Friday, February 20, 2026. Our colleagues Amruta Navadagi, Anaya Kalawat, and Mohammad Mehtabuddin will be waiting to assist you...
amnavada by Cisco Employee
  • 13547 Views
  • 29 replies
  • 1 Helpful votes
Hi All, Quick help (I think it is simple for ACI Specialists;). Please see the below topology.: ACI Main Fabric is built in São Paulo room and the customer needs to expand the fabric in new room which is 800m away from the Main ACI Fabric – same DC, ...
Translator by Administrator
  • 330 Views
  • 2 replies
We are having a very difficult time with our Cisco C9200L-48P-4X and C9300L-48P-4X switches after converting them to be managed through the Meraki Dashboard.Initially, everything works fine, but after some time we start experiencing a number of issue...
Singhaam by Level 4
  • 117 Views
  • 2 replies
I bought a Cisco Catalyst switch from a hamfest (amateur radio swap meet) and am trying to get it working.  I am a retired software engineer and am just looking to get this working.  I can connect to it through a serial conection and can run some ini...
I am testing FlexStack in my lab using two Catalyst 2960-X switches running IOS 15.2(7)E14.While the stack appears to be fully formed and healthy according to show switch detail and show switch stack-ring speed, there is an inconsistency in the outpu...
Hi All,We have been experiencing frequent switch hangs and downtime on the WS-C3650-8PC-S switch.Observations:Power supply has been checked and is functioning properly.All switch LEDs remain stable, but the device is not reachable via ping.After a re...
Hello,I am looking at setting up an industrial Ethernet network comprising multiple Cisco IE switches connected using Device Level Ring (DLR). The network uses multiple VLANs so the ports used for the DLR links will be configured as dot1q trunks.My q...
