How to configure a multicast network?
winstonlimsk
It has been quite sometime since I have configured a multicast network. Yesterday I tried configuring it on the Production environment but didn't work. We have the multicast servers connected directly to the Core Switch (x2) and I can see the switch is receiving multicast packets but it is not forwarding to the ASA firewall. We have many more devices after the ASA but I am stuck on the first two devices. Can someone help to see what is missing from the config below?
Core switch (C3560X-48T-E) configuration
CORE-SW1
ip multicast-routing distributed
no ip igmp snooping
interface GigabitEthernet0/3
description "ASA-FW1:e0/1"
switchport access vlan 103
switchport trunk native vlan 103
switchport trunk allowed vlan 103
switchport mode trunk
interface Vlan103
description ACCESS
ip address 10.12.3.5 255.255.255.0
ip pim sparse-dense-mode (newly added)
standby 103 ip 10.102.3.4
standby 103 priority 110
standby 103 preempt delay minimum 30
standby 103 name ACC
CORE-SW2
no ip igmp snooping
description "ASA-FWFO:e0/1"
interface Vlan103
description ACCESS
ip address 10.12.3.6 255.255.255.0
standby 103 ip 10.12.3.4
standby 103 priority 90
standby 103 preempt
ASA-FW1 (ASA 5510)
multicast-routing
interface Ethernet0/0
description WAN-SWITCH
nameif WAN
security-level 0
ip address 10.12.9.1 255.255.255.0 standby 10.12.9.2
igmp static-group 239.192.0.45
interface Ethernet0/1
description ACCESS
nameif ACC
security-level 100
ip address 10.12.3.1 255.255.255.0 standby 10.12.3.2
igmp join-group 239.192.0.45
ASA-FW1# sh mroute
Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group,
       C - Connected, L - Local, I - Received Source Specific Host Report,
       P - Pruned, R - RP-bit set, F - Register flag, T - SPT-bit set,
       J - Join SPT
Timers: Uptime/Expires
Interface state: Interface, State
(*, 239.192.0.45), 02:28:46/never, RP 0.0.0.0, flags: DCL
  Incoming interface: Null
  RPF nbr: 0.0.0.0
  Immediate Outgoing interface list:
    POS, Forward, 00:13:32/never
    WAN, Forward, 02:28:46/never
ASA-FW1# sh mroute count
IP Multicast Statistics
5 routes, 3 groups, 0.00 average sources per group
Forwarding Counts: Pkt Count/Pkts per second/Avg Pkt Size/Kilobits per second
Other counts: Total/RPF failed/Other drops(OIF-null, rate-limit etc)
Group: 239.192.0.45
  RP-tree:
Yashas Bhadoria
Hello, first from your config I can see that on gig0/3 you are making the vlan an access vlan then converting finally it into a trunk, that is also creating issues.
Please refer thefollowing guide to Configuring IP Multicast Routing on 3560:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3560/software/release/12-2_52_se/configuration/guide/3560scg/swmcast.html
