Error opening tftp....
taikihashimoto
Community Member
Regarding tftp, I want to  "copy tftp:config run" but Error opening tftp....
I set 192.168.0.1/24 on Port1 of C2960, switch1, stand alone and 192.168.0.1 on nic on Computer that launching tftp server. Ping are successful each other.
I tried connecting other C2960, switch2 with same tftp setting via DHCP, tftp transer is successful.
I assume tftp is udp, layer4 must be on layer3 So tftp needs router?
Anyway switch1 is supposed to be problem.....
Leo Laohoo
The syntax is incorrect.  It should be "copy tftp://<TFTP IP Address>/filename run".
veevekraj
Frequent Visitor
Frequent Visitor
how you can configure same ip on PC NIC and switch ! Also ip can not be configured on 2960 port because it's L2 switch.You can configure ip on virtual interface.
I did as follows:-
configure ip on virtul interface> put any port on that vlan >configure ip of same subnet in PC>connect copper cable from pc to that switch port> run tftp on PC> then execute command and give the details of tftp asked by switch. or copy tftp://tftp_ip_add/filename destination path
Yashas Bhadoria
  • TFTP— tftp: [[ // location ] / directory ] / filename
  • Use one of these privileged EXEC commands:
    • copy tftp: [[[ // location ] / directory ] / filename ] system:running-config
    • copy tftp: [[[ // location ] / directory ] / filename ] nvram:startup-config
Please refer the following guide
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_53_se/configuration/guide/2960scg/swiosfs.html
