How to Configure Linksys Modem for DSL Line with Cisco 1861
Vikrant Ambhore
Hello All Friend's,
We have just finish configuration on Cisco 1861 router, but i am unable to browse Internet from Cisco 1861, we have DSL line with Dynamic IP & our ISP is OPTUS  In Melbourne.
We have Physical connection as per below :
Internet provider (OPTUS)<---> Linksys Modem(AM300 & IP :192.168.1.1/24) <---> Cisco 1861 (LAN IP, 192.168.8.1) <---> Workstation (192.168.8.2 to 192.168.8.254),
But We can't access Internet from Cisco Device, I'm not sure about Linksys modem. Can anyone suggest me what configuration need to be done on Linksys for getting Internet from Cisco Device..
How to Configure Linksys router for DSL Line with Cisco 1861 ?
Vikrant
6 Replies 6
dixho
Level 6
Level 6
Please provide the router configuration. To be specifically, which interface on the 1861 connecting to the Linksys AM300?
In general, you need to assign the interface on the 1861 connecting to the Linksys AM300 on the IP subnet 192.168.1.0/24 (e.g. 192.168.1.2). Configure global command ip route 0.0.0.0 0.0.0.0.0 192.168.1.1 on the 1861.
Then, you go to Advanced Routing in the Linksys AM300. Define a static route with desitination IP address 192.168.8.0, subnet Mask 255.255.255.0, and Default Gateway 192.168.1.2.
Hello mate,
Thanks for your intrest to help me,
I am very frusted from this issue, Please look on my running config, apart from this i have one question Which option should select on Linksys for configure it, there is more option like PPPoe, PPPoa, bridge etc. i hope my cisco config is good but realy i need help for setup Linksys
Hi Vikrant
Very similar query has been addressed and resolved here :
https://supportforums.cisco.com/message/3225106
One simple mistake i could see is that you are having 2 different NAT overload statements and one attached to Fa0/0 which is not configured with any ip.
Try to remove that off from your config and refer the above link.
regds
From the Linksys AM300 configuration, I suggest that you talk to your ISP. I am guessing that you should use RFC2516 PPPoE. At least, that' how my house works. I suggest that you simply connect a PC directly to the Linksys AM300. If the PC can access Internet, you proceed the followings.
From the router configuration, you configure PPPoE on the 1861. Normally, ATM interface is used for DSL interface in Cisco router. At least, that's how it works in US.  I do not see any ATM interface on the 1861. Thus, I assume that the dialer interface is redundent.
IRB is configured on the 1861. I do not think that you need that at all. NAT is not required on the 1861 because the Linksys AM300 should do NAT/PAT. You configure 192.168.1.2/24 on Fa 0/0. Remove subinterface fa 0/0.50 and fa 0/0.100. I attached the modified configuration.
I do not know enough on verifying the VPN and VOIP configuration.
Hello Friends,
Thanks for your help, I have attached my Present running configuration also Screen Shot of modem,
Can you please look on this, & I request to you please let me know if I'm wrong anywhere ?
I got two otion in Interface while configuring Static router on ADSL modem, LAN & WAN_Main, I selected LAN also I put 1 in cost option..
Please look Topology Melbourne.jpg this is my network Diagram
Vikrant
Still Having same issue
Melbourne1861#ping ip X.X.X.X  source fastEthernet 0/0
Sending 5, 100-byte ICMP Echos toX.X.X.X timeout is 2 seconds:
Packet sent with a source address of 192.168.1.2
Success rate is 0 percent (0/5)
