How to monitor traffic passing through routers???
pallavireddy.
Hi ,
Is there a tool to monitor the type of traffic passing in and out of the routers ( broadcast/multicast traffic)???
Any suggestions????
Pallavi
bjw
Level 4
Level 4
Try
router> show ip cache flow
IP Flow Switching Cache, 4456704 bytes
718 active, 64818 inactive, 629689258 added
646291620 ager polls, 0 flow alloc failures
Active flows timeout in 1 minutes
Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 336520 bytes
738 active, 15646 inactive, 636429655 added, 629665327 added to flow
0 alloc failures, 0 force free
1 chunk, 11 chunks added
last clearing of statistics never
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
TCP-Telnet 512693 0.1 2 45 0.3 9.0 7.5
TCP-FTP 990 0.0 3 59 0.0 1.0 15.3
TCP-FTPD 998 0.0 1 218 0.0 0.2 19.3
TCP-WWW 116394659 27.1 13 613 377.2 2.1 6.7
TCP-SMTP 3445 0.0 88 703 0.0 1.0 6.9
TCP-X 322 0.0 1 50 0.0 0.4 20.3
TCP-BGP 618 0.0 1 45 0.0 0.0 19.7
TCP-NNTP 618 0.0 1 45 0.0 0.0 19.7
TCP-Frag 304 0.0 1 115 0.0 0.4 15.5
TCP-other 237584262 55.3 22 303 1271.6 1.9 7.4
UDP-DNS 3977636 0.9 2 69 2.6 3.1 15.4
UDP-NTP 65652192 15.2 1 83 15.4 0.0 15.4
UDP-TFTP 34944 0.0 1 66 0.0 1.3 15.5
UDP-Frag 81955 0.0 1 33 0.0 1.8 15.4
UDP-other 119511713 27.8 50 438 1403.0 2.8 15.1
ICMP 68775460 16.0 1 69 19.6 0.3 15.4
GRE 891569 0.2 184 503 38.3 52.9 3.6
IP-other 11616061 2.7 14 60 37.9 58.4 1.9
Total: 625040439 145.5 21 397 3166.4 2.9 10.4
Collin Clark
NBAR and/or Netflow
depending on what Pallavi is really looking for another possibility to consider would be show ip traffic. An example of what it show:
test_router>sh ip traffic
IP statistics:
Rcvd: 2574231 total, 393590 local destination
0 format errors, 0 checksum errors, 12 bad hop count
0 unknown protocol, 0 not a gateway
0 security failures, 0 bad options, 0 with options
Opts: 0 end, 0 nop, 0 basic security, 0 loose source route
0 timestamp, 0 extended security, 0 record route
0 stream ID, 0 strict source route, 0 alert, 0 cipso, 0 ump
0 other
Frags: 0 reassembled, 0 timeouts, 0 couldn't reassemble
305 fragmented, 735 fragments, 0 couldn't fragment
Bcast: 1428 received, 11060 sent
Mcast: 101395 received, 102033 sent
Sent: 198096 generated, 917651 forwarded
Drop: 879 encapsulation failed, 0 unresolved, 0 no adjacency
78 no route, 0 unicast RPF, 0 forced drop
0 options denied
Drop: 0 packets with source IP address zero
Drop: 0 packets with internal loop back IP address
ICMP statistics:
Rcvd: 0 format errors, 0 checksum errors, 0 redirects, 89 unreachable
30856 echo, 0 echo reply, 1 mask requests, 0 mask replies, 82 quench
0 parameter, 1 timestamp, 1 info request, 0 other
0 irdp solicitations, 0 irdp advertisements
Sent: 0 redirects, 53 unreachable, 0 echo, 30856 echo reply
0 mask requests, 0 mask replies, 0 quench, 1 timestamp
0 info reply, 12 time exceeded, 0 parameter problem
TCP statistics:
Rcvd: 2975 total, 0 checksum errors, 107 no port
Sent: 3405 total
IP-EIGRP statistics:
Rcvd: 107210 total
Sent: 107862 total
PIMv2 statistics: Sent/Received
Total: 0/0, 0 checksum errors, 0 format errors
Registers: 0/0 (0 non-rp, 0 non-sm-group), Register Stops: 0/0, Hellos: 0/0
Join/Prunes: 0/0, Asserts: 0/0, grafts: 0/0
Bootstraps: 0/0, Candidate_RP_Advertisements: 0/0
Queue drops: 0
State-Refresh: 0/0
IGMP statistics: Sent/Received
Total: 0/0, Format errors: 0/0, Checksum errors: 0/0
Host Queries: 0/0, Host Reports: 0/0, Host Leaves: 0/0
DVMRP: 0/0, PIM: 0/0
Queue drops: 0
UDP statistics:
Rcvd: 45448 total, 0 checksum errors, 1432 no port
Sent: 55909 total, 0 forwarded broadcasts
OSPF statistics:
Rcvd: 0 total, 0 checksum errors
0 hello, 0 database desc, 0 link state req
0 link state updates, 0 link state acks
Sent: 0 total
ARP statistics:
Rcvd: 173178 requests, 1 replies, 0 reverse, 0 other
Sent: 264 requests, 3611 replies (0 proxy), 0 reverse
Rick
Rick
Hi!
Good Day! NBAR and NetFlow are the right tool if you are to monitor traffic up to Layer 7. Routers should have IOS that supports NetFlow. When enabled, NetFlow gets traffic samples on router interfaces and forwards it to applications that gathers and displays these information. NBAR is quite similar in nature. This are great tools that provides high level monitoring but would require additional resources to implement.
To know more about these tools, please check the following links:
Network Based Application Recognition Performance Analysis
http://www.cisco.com/en/US/products/ps6616/products_white_paper0900aecd8031b712.shtml
NBAR Q&A
http://www.cisco.com/en/US/products/ps6616/products_qanda_item09186a00800a3ded.shtml
Cisco CNS NetFlow Collection Engine
http://www.cisco.com/en/US/products/sw/netmgtsw/ps1964/products_data_sheet09186a00801e4ebb.html
Hope this helps,
Thanks and Regards,
Albert
