how to reset stacked switches to factory default
Alex Wu
Hello All,
I have 2 stacked Catalyst 2906s switches, how to reset them to factory default simultaneously?
thanks.
I found that stack is still working..
Of course it's still working.  The stacking cable is still connecting both units.
8 Replies 8
Leo Laohoo
Use the command "wr erase" and check for the presence of "config.text" and "vlan.dat" files.  If the files are no longer present, reboot.
i used command "write erase" and also deleted ''vlan.dat",
but after "reload", the stack is still working...
What do you mean "stack still working"?  Was the stacking cable removed or not?
I didn't remove the stacking cable, but I powered off one switch (A), the powered on the other switch (B), after rebooting, I powered on the switch B, I found that stack is still working..
Got it.
Thank you very much.
maeh.ayi01
#switch clear stack-mode
does this mean that the switch is unstacked?
H/W Current
Switch# Role Mac Address Priority Version State
*1 Master b0fa.ebfa.ac00 5 1 Ready
