How to reset?
What is the command to reset specific interface?(for eg; have to reset interface gi7)
13 Replies 13
Use defualt command
MHM
Mark Elsen
 - It depends a bit on the meaning of reset (intention) ; the mentioned default command resets to default settings for the interface ; if we talk about network connectivity problems or speed mismatch (e.g.) sometimes it helps to shutdown the interface and enable it again
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
Depends on the device, i take this as Switch -
config t
default interface gig 1/0/7 (example replace the interface name you like to setup to default)
end
Note : if the interface part of any Port-channel - disconnect the physical cable and do the default interface or any device connected remove and default the interface-  once you default the interface it go default to VLAN1 (so make sure no device connected to port before you default)
BB
not accepting the command.
can I see
# default ? <<- check what the option you have via "?"
MHM
what device model - show version help here (if further assitance required)
You post 2 different device and you need to provide the model - help here
most of the device default should work as expected.
BB
It's CISCO switch - SG350.
If the switch is small business - that command not available on those models, the command only available enterprise grade switches.
may be you can try macro commands (not tried myself - since i dont have that switch to test)
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-350-series-managed-switches/smb5842-configure-auto-smartport-properties-switch-through-cli.html
BB
is this possible to reset all the configuration only in [int gig12] in single command? in the above image, if yes then how??
friend
I config IP in interface f0/0
then I use
default interface f0/0
and all config is remove
Blue_Bird
Hello anb07configterminal,
give  default interface Gig 7 in gloable configuration mode, it resets the configuration to default only on that specific interface...
Best regards
******* If This Helps, Please Rate *******
Use command in Configuration mode, which will bring your interface to default configuration.
default int gig X/X
Default int range gig X/X - X (for multiple interfaces)
Blue_Bird
Hi anb07configterminal,
I think...that is (default interface command) not possible to achieve in this model....
Reference: https://community.cisco.com/t5/switching/clear-switchport-config-on-sg300-sg350/td-p/3837068
Best regards
