How to see 3850 PBR hits?
malcolmsalmons
I've recently deployed PBR on catalyst 3850s and everything looks to be working ok. However I'm not seeing hits on the ACL or Route-map. I'm using the following commands to try and see hits:
Show access-list
Show ip policy - to check its applied
Show route-map PBR_TRAFFIC
I can't see any hits under these and was wondering if the configs right or if I'm not using the correct command to verify hits. I seem to remember that on the 6500 you had to look in TCAM for hits and was wondering if this is something similar?
Malcolm
Emmanuel Valdez
Level 3
Level 3
Did you try with "show route-map" only? You have to see a similar output like this:
c2921_internet#sh route-map
route-map INTERNET_INVITADOS, permit, sequence 10
  Match clauses:
    ip address (access-lists): 103
  Set clauses:
    ip next-hop 10.1.100.3
  Policy routing matches: 2025356 packets, 206821491 bytes
route-map INTERNET_USUARIOS, permit, sequence 20
  Match clauses:
    ip address (access-lists): 102
  Set clauses:
    ip next-hop 192.168.99.11
  Policy routing matches: 20253 packets, 206820 bytes
If it was useful please rate.
Regards.
