How to tell if anything is connected to a switch port
dan_track
I've got a basic problem where I can't tell for sure whether a workstation is plugged into a switchport or not. I know that a port will say "notconnected" when running "sh int status" but how do I know what the workstation hasn't been turned off and it reporting the connection incorrectly. Any ideas would be appreciated.
Dan
Jon Marshall
Dan
Short answer is you don't really. The "notconnected" simply means there is no active device on that port, the key word being active. So a PC, laptop etc.. connected to that port but shutdown will not show up.
Jon
7 Replies 7
Jon Marshall
Dan
Jon
There is no way of finding if the system connected to the switcport is shutdown.
However, we can check the MAC table entry to see if there ia any entry for the specific port.
{P.S : This mainly depends on the age-out timer configured}
Thanks for letting me know. So my only way is to visually check.
mlund
Level 7
Level 7
You can have a hint if this interface has ever been used.
#show interface
0 packets input,
#show version
uptime is 2 years, 20 weeks, 4 days, 22 hours, 56 minutes
with theese two commands you can see, no packests have been received in over 2 years.
Of course, this doesn't mean nothing is connected, but it's less likely to be.
If the uptime is shorter, it will be more unsecure.
If you are talking a 4500 using the "show interfaces link " will tell you when it was last used .Don't know why they don't use this command on all switches .
Leo Laohoo
Hi Dan,
When a host is powered off, the NIC received power from the power point and would continue to light up and you will see a response from the switch. However, if the host has it's power removed, the NIC will "die" and thus the response is "notconnect".
Does this help?
Hello Dan,
If you know the mac address of the NIC on the host. Try show mac-address-table address - it should display
or show mac-address-table interface
Mat
