how to verify jumbo frames ?
nflnetwork
WS-C2960X-24PS-L
How can i verify if a specific port is configured correctly to accept jumbo packets?
CISCO2960stk#
CISCO2960stk#sh int gi1/0/17 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
CISCO2960stk#
luis_cordova
Hi @nflnetwork ,
Check this link:
https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-c03384883
It has some information that could be useful to you.
Remember to mark the correct answers as solved, because that helps other users with similar doubts.
balaji.bandi
Adding to other note :
The standard data frame has 1500 MTU size and the jumbo frame is typically set at 9000 MTU value size when enabled.
CISCO2960stk#sh int gi1/0/17   <-- this will show you MTU Size
You do extended ping to test the jumbo MTU by setting df-it. (from Cisco device)
From windows -
ping -f -l 9000 10.10.10.10  << this destination IP
BB
Leo Laohoo
Post the complete output to the command "sh interface <BLAH>" &/or "sh run | i mtu".
If the switch is configured for jumbo frames then the MTU value should be higher than 1500.
