HSRP on nexus 5000
Is the routing module needed for HSRP to operate?
I do not have such module but I was able to configure the feature but it seems they do not communicate both 5Ks remain active and the virtual IP is not reachable.
The VLAN is allowed over the vPC pee-link
Here's my config
N5K-SW1# sh runn int vlan 999
!Command: show running-config interface Vlan999
!Time: Wed Jan  7 03:39:42 2009
version 5.1(3)N1(1)
interface Vlan999
  no shutdown
  ip address 10.71.234.252/24
  hsrp 1
    ip 10.71.234.254
N5K-SW1# sh int vlan 999
Vlan999 is up, line protocol is up
  Hardware is EtherSVI, address is  547f.ee60.1281
  Internet Address is 10.71.234.252/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
N5K-SW1# sh hsrp interface vlan 999
Vlan999 - Group 1 (HSRP-V1) (IPv4)
  Local state is Active, priority 100 (Cfged 100)
    Forwarding threshold(for vPC), lower: 1 upper: 100
  Hellotime 3 sec, holdtime 10 sec
  Next hello sent in 0.836000 sec(s)
  Virtual IP address is 10.71.234.254 (Cfged)
  Active router is local
  Standby router is unknown
  Authentication text "cisco"
  Virtual mac address is 0000.0c07.ac01 (Default MAC)
  2 state changes, last state change 00:00:29
  IP redundancy name is hsrp-Vlan999-1 (default)
N5K-SW1# ping 10.71.234.253
PING 10.71.234.253 (10.71.234.253): 56 data bytes
64 bytes from 10.71.234.253: icmp_seq=0 ttl=254 time=3.262 ms
64 bytes from 10.71.234.253: icmp_seq=1 ttl=254 time=4.868 ms
64 bytes from 10.71.234.253: icmp_seq=2 ttl=254 time=4.975 ms
64 bytes from 10.71.234.253: icmp_seq=3 ttl=254 time=2.969 ms
64 bytes from 10.71.234.253: icmp_seq=4 ttl=254 time=2.975 ms
N5K-SW2# sh runn int vlan 999
!Time: Wed Mar 18 15:06:48 2009
version 5.1(3)N1(1)
interface Vlan999
  no shutdown
  ip address 10.71.234.253/24
  hsrp 1
    ip 10.71.234.254
N5K-SW2# sh int vlan 999
  Hardware is EtherSVI, address is  547f.ee60.11c1
  Internet Address is 10.71.234.253/24
N5K-SW2# sh hsrp interface vlan 999
  Next hello sent in 1.450000 sec(s)
  2 state changes, last state change 00:23:13
N5K-SW2# ping 10.71.234.252
PING 10.71.234.252 (10.71.234.252): 56 data bytes
64 bytes from 10.71.234.252: icmp_seq=0 ttl=254 time=3.05 ms
64 bytes from 10.71.234.252: icmp_seq=1 ttl=254 time=3.453 ms
64 bytes from 10.71.234.252: icmp_seq=2 ttl=254 time=3.515 ms
64 bytes from 10.71.234.252: icmp_seq=3 ttl=254 time=2.987 ms
64 bytes from 10.71.234.252: icmp_seq=4 ttl=254 time=2.99 ms
--- 10.71.234.252 ping statistics ---
5 packets transmitted, 5 packets received, 0.00% packet loss
round-trip min/avg/max = 2.987/3.199/3.515 ms
Chad Peterson
Hi Maarten,
For HSRP or any L3 protocol to run you will need the L3 daughter card.  The software is still there in NX-OS so it itself is not depending on it.  You'll see similar issue if you were to run EIGRP or some other routing protocol.
I'd think an enhancment could be added that would allow you to configure this (say for prep for your l3 card) but alert you that it won't be functional.
If you have further questions about this, we can continue here.  Also note you can open a case with the PDI Datacenter help desk here:
www.cisco.com/go/pdihelpdesk
Hope that helps
Chad
HI,Chad,I have an issue similar with Maarten's.Though I have a l3 routing card of 160G/S,I failed to make the HSRP successful.they do not communicate with each other for HSRP.Each thinks itself active and the virtual IP is not reachable.
Here is my config
version 5.1(3)N1(1a)
vrf context management
  ip route 0.0.0.0/0 192.168.150.2
vpc domain 1
  peer-keepalive destination 192.168.150.2
  peer-config-check-bypass
  delay restore 5
  peer-gateway
  auto-recovery
  ip arp synchronize
interface Vlan11
  no shutdown
  no ip redirects
  ip address 10.113.7.252/24
  hsrp 11
    preempt
    priority 110
    ip 10.113.7.254
interface mgmt0
  ip address 192.168.150.1/30
interface port-channel20
  switchport mode trunk
  spanning-tree port type network
  speed 10000
  vpc peer-link
I can not find what 's wrong with the configration,but the result is.......
N5K-core-1# sh hsrp group 11
Vlan11 - Group 11 (HSRP-V1) (IPv4)
  Local state is Active, priority 110 (Cfged 110), may preempt
    Forwarding threshold(for vPC), lower: 1 upper: 110
  Next hello sent in 0.373000 sec(s)
  Virtual IP address is 10.113.7.254 (Cfged)
  Virtual mac address is 0000.0c07.ac0b (Default MAC)
  2 state changes, last state change 00:33:03
  IP redundancy name is hsrp-Vlan11-11 (default)
I think I would be crazy,my god.
Devavrat Oka
Maarten, even though you see HSRP related configs on NX-OS, it is not available without an L3 daughter card and license on the 5K.
It is similar to seeing feature glbp on the 5K, but glbp not being available on the 5K. When NX-OS was written, it wasn't segregated keeping in mind 5K vs 7K unlike the IOS for say a 3750 switch vs a 3925 router.
