HSRP question?
praveennoc
I started learining CCNP swtiching
1)If we give same priority value in active and stand by device ,how redundcy will work ?
2)How Preempt works in HSRP?
Thanks in advance
3 Accepted Solutions
devdeep98
Community Member
Dear All,
            HSRP is a cisco propriotary protocol created in 1994.Uses multicast address 224.0.0.2 with UDP port 1985 to communicate with HSRP routers within the group.HSRP uses a virtual IP and virtual mac 0000.0c07.acXX where XX is the HSRP group number.Basically all the FHRP's are ment to provide Gateway redundacy for end devices.
The higher priority router will act as a Active or who has the highest physical interface IP address will be the Active,lower priority/IP address router will act as Standby.And to Take Over from lower enable "PREEMPT".Simply the HSRP group routers sends periodic Hello's after 3 seconds on multicast address 224.0.0.2 udp 1985 to check the Active router's availability and if Active goes the standby will take over ...........Here is the scoope.......what if Active router is up and running and your ISP link is down ......In that case the standby will not take over however it is configured to preempt............I am writing all configuration for the HSRP below have a look and that's it....you are done with HSRP.................... ...configure interface IP schemes on your own Ok.......
R1(config)#int f0/0
R1(config-if)#standby 10 ip 192.168.10.3
R1(config-if)#standby 10 preempt
R1(config-if)#standby 10 priority 150
R1(config-if)#standby 10 track serial 0/0 60
NOTE :-
1. The last command will decrement the actual priority of 150 by 60 which is 90.That means now standby will now take over however the R1is up.As it has now decremented priority of 90.............but the R1's serial 0/0 is down(the link to ISP cloud is down).
Once the R1's serial 0/0 interface will come up the R1 will be the active router again as the priority will become 150 again automatically.
2.You can use IP SLA as well to track the interface.
R2(config)#int f0/0
R2(config-if)#standby 10 ip 192.168.10.3
R2(config-if)#standby 10 preempt
R2(config-if)#standby 10 priority 110
NOTE :- Normal configuration would be applied on R2 with "preempt enable, keep in mind"if want failover.
Kevin Dorrell
Level 11
Level 11
100
P.S. Sorry, I didn't see Joseph's reply due to quirk of the Android app display.
Sent from Cisco Technical Support Android App
15 Replies 15
Inderjeet Singh
Level 2
Level 2
Praveen,
If you do not give priority in HSRP than the device which comes live first or which receives configuration first will become active and the other will become standby..
the use of preempt is like, if you have two routers and R1 is active and R2 is standby.. if R1 fails than standby R2 will takeover and will become active.. but if after sometime, R1 is back, it will take priority over R2 and will become active again.. if you do not use preempt, R2 will continue to be active unless R2 reboots or fails..
I hope it would be clear.. please rate the answer if it is helpful.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
#1
If standby fails, nothing changes.  If standby recovers, nothing changes.
If active fails, standby becomes active.  If previous active recovers, it becomes standby.
#2
When a "new" HSRP member becomes active, if its priority is higher than current active, it becomes new active.
devdeep98
Community Member
Dear All,
R1(config)#int f0/0
NOTE :-
R2(config)#int f0/0
Thank you to all
What is the default priority number in HSRP
100
It is 100 but you can play with it..............the loveliest part is set priorities on your own on both routers......with tacking.
One more thing if you want to load balance through HSRP.......you can do that as well by creating two different groups of HSRP......and assign the interfaces/vlan into that ......will do the load balancing for your end system devices based on round robin method........................................But you know what I will recomend GLBP if you are using 4500 or 6500 switches.............it will do load balancing as well and you would have more load balancing methods like round robin, Host dependent and Weighted....................awesome GLBP fall in love......................
One more key information guys................On layer 3 always the Highest IP or Priority wins.................and if you talk about layer 2 Lowest Mac address wins......keep in mind always..........whatever you implement or configure............
WHAT HAPPEND IF TWO ROUTERS HAS SAME PRIORITY?
Wish all the best
Hi Parvin
in that case tof equal priority he router with the highest address for the respective group is elected as active.
https://www.cisco.com/c/en/us/support/docs/ip/hot-standby-router-protocol-hsrp/9281-3.html#q4
Please don’t forget to rate if this is helpful.
FA
HI  Felipe i have a second question. which kind of configuration i need to save last my entry in router. like this picture 782de61ffa.png
Wish all the best
Hi Parvin,
I hope I understand your question correctly but I will give it a shot. you probably need to configure the clock or NTP on your device in question in order to display it.   Please make sure that you have either an NTP server or the clock set.
ntp server 192.162.1.254 prefer
or
Set the clock on the device itself locally.
Also make sure that your time zone's are configured correctly to reflect your area.
clock timezone EST -5 0 (your timezone)
clock summer-time EDT recurring
Hope this helps,
FA
Hi FELIPE, thank you for support i done it by another way
i made one user
AAA new-model
aaa authentication login default local-case
Wish all the best
Hi devdeep98 i have question in one router how many sub interface we can made
Wish all the best
@Mlex1 greetings,
Maximum Number of Interfaces
Every interface uses an IDB. Therefore, the IDB limit indicates the maximum number of interfaces a router can handle.
The IDB limit is, therefore, the answer to the common question "How many (sub)interfaces can be configured on this platform?"
Maximum Number of VLANs
Each Virtual LAN (VLAN) requires one IDB. Any Cisco IOS software release can support up to 4096 VLANs (0-4095, where the number range is 1 to 4094 and in which 0, 4095 are reserved), if the platform supports at least 4000 IDBs
There is a limitation of 256 bridge groups in the Cisco IOS software release if you use VLAN bridging.
"Maximum Number of Interfaces and Subinterfaces for Cisco IOS Routers: IDB Limits"
If you are alluding to a router on a stick scenario (?) then it will depend on how many IDBs the platform can handle. A SWIDB represents a logical sub-interface and you can use the IOS command 'show idb' for existing allocations and the memory consumed.
Each interface uses an IDB and the limit therefore indicates the maximum number of interfaces a router can handle.
You need to know how many IDBs your particular platorm can configure (see above). Commonly this can correlate to the max number of vlans configurable because each vlan will require 1 IDB (normally 4094 in cisco IOS).
Please don't forget to rate all helpful responses and mark solutions!
Bst Rgds,
Andrew Khalil
Kevin Dorrell
Level 11
Level 11
100
