Im a little confused, trying to learn :)
cventicinque
I have a 1605r connected to a cable modem that I use to both connect my little home lan to the internet and to learn cisco networking. I ran into a weird problem tonite. I am reading the Lammle book in preperation for my CCNA and I started fooling around with my config. Of course, I broke my config. I ended up fixing it but, I dont understand what happened:
sh ver
IOS (tm) 1600 Software (C1600-K8OSY-M), Version 12.2(23)
I removed this line from my config, assuming it was worthless because I did not apply it to any interface:
access-list 1 permit 192.168.1.0 0.0.0.255
Im not sure where that line came from. I assume I was going to play with access lists at some point but, I guess I dropped it and just left the line in there. I thought the line would not have any affect on my config if I did not apply it to an interface.
Evidently it is a big deal because I could not surf without it. Now I know I upgraded my IOS sometime back and I am taking a shot in guessing that this newer IOS with security features needs that line? I had assumed that since I did not change my config after upgrading to the security feature version of IOS that no firewall functions were working on my router, am I wrong?
Sorry if this post is confusing... now you know how I feel :)
See full sanitized config below:
Current configuration : 1806 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname M1605r
enable secret
ip subnet-zero
no ip source-route
no ip bootp server
interface Ethernet0
desc to cable modem
ip address dhcp
no ip proxy-arp
ip nat outside
no cdp enable
interface Ethernet1
desc to Cisco WS-C2912-XL
no ip proxy-arp
ip nat inside
no cdp enable
ip nat inside source list 1 interface Ethernet0 overload
ip nat inside source static tcp 192.168.1.101 6881 interface Ethernet0 6881
ip nat inside source static udp 192.168.1.101 6881 interface Ethernet0 6881
ip nat inside source static tcp 192.168.1.101 6112 interface Ethernet0 6112
ip nat inside source static tcp 192.168.1.101 3724 interface Ethernet0 3724
ip nat inside source static udp 192.168.1.101 2934 interface Ethernet0 2934
ip nat inside source static udp 192.168.1.101 2935 interface Ethernet0 2935
ip classless
ip route 0.0.0.0 0.0.0.0 x.x.x.x 254
no ip http server
no cdp run
banner login ^CC
WARNING!!!
This system is soley for the use of authorized users for official purposes.
You have no expectation of privacy in its use and to ensure that the system
is functioning properly, individuals using this computer system are subject
to having all of their activities monitored and recorded by system
personnel. Use of this system evidences an express consent to such
monitoring and agreement that if such monitoring reveals evidence of
possible abuse or criminal activity, system personnel may provide the
results of such monitoring to appropriate officials.
^C
line con 0
password
login
line vty 0 4
exec-timeout 0 1
no login
no exec
transport input none
end
olorunloba
Level 5
Level 5
It is not a security or firewall issue. The access-list is part of your NAT configuration. It specifies the address that should be translated. These are your relevant NAT configuration.
interface Ethernet0
desc to cable modem
ip address dhcp
ip nat outside
interface Ethernet1
ip nat inside
The 1 in the following line
refers to access-list 1. And in your config, it is translated to the address of E0 which is obtained via DHCP from your provider.
olorunloba
Level 5
Level 5
interface Ethernet0
desc to cable modem
ip address dhcp
ip nat outside
interface Ethernet1
ip nat inside
Wow. I thought I understood my NAT config. I was not expecting that. Thank you very much for explaining that to me.
The more you think you know, the more realize you dont know :)
