import export between VRF and GRE tunnel
i have a question.
I would like to import export routes between VRF's and use OSPF for this.
But the difficult part is that i want to do this accross a GRE Tunnel.
As below is shown.
VRF TEST1 is fully operational and i would like to import TEST2
How can i accomplish this ?
THANKS
Most important thing I forgot to ask. What about your MP-BGP configuration?
You should have a vrf address-family for TEST2 and redistribute the routes there. There's no need of neighbor configuration. Just something like this:
router bgp 1
 address-family ipv4 vrf TEST2
 redistribute connected
Take a look at this link about inter vrf route leakage.
And regarding RD and RTs, here.
10 Replies 10
Moh Mogh
Hi Johan,
I guess, you will need to add route-target import/export for vrf TEST1 to import/export routes of vrf TEST2 , hence the GRE tunnel is based on vrf TEST1. This solution called Inter VRF route leaking.
Mohammad
Hello Mohammad,
Thanks for your reply!.
i tried this:
ip vrf TEST1
 rd 65000:1
 route-target export 65000:1
 route-target import 65000:1
 route-target import 65000:2
ip vrf TEST2
 rd 65000:2
 route-target export 65000:2
but after this still no routes are visible in both VRF's.
Hi Johan,
Please try it like this:
ip vrf TEST1
 rd 65000:1
ip vrf TEST2
 rd 65000:2
Mohammad
Tried it but still no luck.
i'm kinda new with VRF so i correct me if i'm wrong
but could i be that i need to create a static route to connect the VRF's?
No, there's no need of static route here.
Do you use the below commands to check the routes?
show ip route vrf TEST1
show ip route vrf TEST2
Yes i'm using the command :
Sounds strange, because you should at least see the connected routes in each vrf.
Could you please paste the output of show ip vrf detail?
VRF TEST1 (VRF Id = 1); default RD 65000:1; default VPNID <not set>
  Interfaces:
    Tu1                   Gi0/0.1
VRF Table ID = 1
  Export VPN route-target communities
    RT:65000:1             RT:65000:2
  Import VPN route-target communities
  No import route-map
  No export route-map
  VRF label distribution protocol: not configured
  VRF label allocation mode: per-prefix
VRF TEST2 (VRF Id = 1); default RD 65000:2; default VPNID <not        set>
  Interfaces:
    Gi0/0.2
VRF Table ID = 1
    RT:65000:2             RT:65000:1
  No import route-map
  No export route-map
router bgp 1
i didn't had BGP after adding that everthing works!
Many thanks Mohammed!!
