input error but no crc
serge123
Level 3
Level 3
Can someone explain what could be causing these input errors
WS-C4503 to CBS3020
Cable did test good and re punch connection today
thanks,
GigabitEthernet2/3 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is 001e.7ad7.81d2 (bia 001e.7ad7.81d2)
Description: To Blade CBS3020
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 4/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000-TX
input flow-control is off, output flow-control is off
Last input 00:00:36, output never, output hang never
Last clearing of "show interface" counters 06:13:43
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 1098000 bits/sec, 726 packets/sec
30 second output rate 18697000 bits/sec, 1595 packets/sec
     23467079 packets input, 29007154284 bytes, 0 no buffer
     Received 5263 broadcasts (5223 multicasts)
     18282 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
   20366435 packets output, 14639132975 bytes, 0 underruns
     0 lost carrier, 0 no carrier
I just found my input errors are cause by Rx-No-Pkt-Buff. I will move the port to a different group and see if this resolved the issue
Reza Sharifi
Can you hardcode the interface to Gig with full duplex on both sides of the connection?
Then clear counters and test again.
That does not help for lack of buffer errors, as the OP stated.
xiaozhenzhao
Community Member
can you show the output by the command「show int g2/3 count err」
serge123
Level 3
Level 3
For thos interested
I was able to match the input errors with Rx-No-Pkt-Buff with the show interface gig 2/3 and the sh int gig 2/3 counters detail. This is when I found out the module was oversubscribe 8:1
Table 5-7 Oversubscribed Port Groupings for Module WS-X4424-GB-RJ45
1, 2, 3, 4
5, 6, 7, 8
9, 10, 11, 12
13, 14, 15, 16
17, 18, 19, 20
21, 22, 23, 24
Can someone explain how to calculate 2:1 ratio actullay it is for this module
WS-X4648-RJ45V+E
Serge
