Installing a 512 Compac Flash on a CAT 6509E
I have a Catalyst 6509E, i want to connect a 512 Compact Flash in the slot disk0 or disk1, but the Catalyst does not detect the cp flash,  i want to do this because i want upgrade the Catalyst ios version, actually the ios version is 12.2(18)SXD7b and want to upgrade to the version 122-33.SXI14.
the compac flash model is MEM-C6K-CPTFL512M
I believe that the problem could be the ROM version, I would like to know if i have to upgrade the ROM version?
Device information:
rtsw64253#show rom-monitor slot 5 sp
Region F1: INVALID
Region F2: INVALID
Currently running ROMMON from S (Gold) region
how version | include ROM
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19 (SP by reload)
rtsw64253#show version
IOS (tm) s72033_rp Software (s72033_rp-PK9SV-M), Version 12.2(18)SXD7b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Fri 08-Dec-06 12:51 by ccai
Image text-base: 0x4002100C, data-base: 0x42320000
BOOTLDR: s72033_rp Software (s72033_rp-PK9SV-M), Version 12.2(18)SXD7b, RELEASE SOFTWARE (fc1)
rtsw64253 uptime is 6 weeks, 1 day, 20 hours, 22 minutes
Time since rtsw64253 switched to active is 6 weeks, 1 day, 20 hours, 22 minutes
System restarted at 17:16:55 horario-verano Wed Oct 1 2014
System image file is "sup-bootflash:s72033-pk9sv-mz.122-18.SXD7b.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.3) with 458720K/65536K bytes of memory.
Processor board ID SMC1037006Q
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
X.25 software, Version 3.0.0.
Bridging software.
20 Virtual Ethernet/IEEE 802.3  interface(s)
48 FastEthernet/IEEE 802.3 interface(s)
106 Gigabit Ethernet/IEEE 802.3 interface(s)
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
rtsw64253#dir /all
Directory of sup-bootflash:/
    1  -rw-    46666996   Oct 1 2014 17:10:47 +02:00  s72033-pk9sv-mz.122-18.SXD7b.bin
65536000 bytes total (18868876 bytes free)
rtsw64253#show module
Mod Ports Card Type                              Model              Serial No.
  1   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX     SAL10457335
  2   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX     SAL104572ZY
  3   48  SFM-capable 48-port 10/100 Mbps RJ45   WS-X6548-RJ-45     SAL10414AH5
  4    8  8 port 1000mb GBIC Enhanced QoS        WS-X6408A-GBIC     SAL10425LZK
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL104254HV
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0019.aa98.5290 to 0019.aa98.52bf  11.1   7.2(1)       8.3(0.156)RO Ok
  2  0019.aa98.4ed0 to 0019.aa98.4eff  11.1   7.2(1)       8.3(0.156)RO Ok
  3  000a.b807.82d0 to 000a.b807.82ff   7.1   6.3(1)       8.3(0.156)RO Ok
  4  0019.56ce.1658 to 0019.56ce.165f   4.1   5.4(2)       8.3(0.156)RO Ok
  5  0014.a982.5d20 to 0014.a982.5d23   5.2   8.4(2)       12.2(18)SXD7 Ok
Mod Sub-Module                  Model              Serial        Hw     Status
  5 Policy Feature Card 3       WS-F6K-PFC3B       SAL104258XK   2.3    Ok
  5 MSFC3 Daughterboard         WS-SUP720          SAL104041SG   2.5    Ok
Mod Online Diag Status
  1 Pass
  2 Pass
  3 Pass
  4 Pass
  5 Pass
rtsw64253#sh module version
Mod Port Model              Serial #    Versions
 1   48  WS-X6548-GE-TX     SAL10457335 Hw : 11.1
                                        Fw : 7.2(1)
                                        Sw : 8.3(0.156)ROC20
 2   48  WS-X6548-GE-TX     SAL104572ZY Hw : 11.1
                                        Fw : 7.2(1)
 3   48  WS-X6548-RJ-45     SAL10414AH5 Hw : 7.1
                                        Fw : 6.3(1)
 4    8  WS-X6408A-GBIC     SAL10425LZK Hw : 4.1
                                        Fw : 5.4(2)
 5    2  WS-SUP720-3B       SAL104254HV Hw : 5.2
                                        Fw : 8.4(2)
                                        Sw : 12.2(18)SXD7b
                                        Sw1: 8.4(0.61)RCC10
         WS-SUP720          SAL104041SG Hw : 2.5
                                        Fw : 12.2(17r)S4
                                        Sw : 12.2(18)SXD7b
         WS-F6K-PFC3B       SAL104258XK Hw : 2.3
Fidel Gonzalez
a12288
Level 3
Level 3
I don't think you need to upgrade rmmon. here is my output. "ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)", and we have core-jnhn#dir disk0: Directory of disk0:/ .... .... 512024576 bytes total (182542336 bytes free)
7 Replies 7
a12288
Level 3
Level 3
Leo Laohoo
Three suspects:
1.  Your CF is dead;
2.  Your CF ports are dead; and
3.  Both 1 & 2.
Recommendation:  Go to your nearest/favorite electronics (or camera) shop and get a variety of CF (up to 2 Gb).  Test them out and see if the logs will show up as something like "CF inserted in diskX:".
When I say "a variety" I mean numerous brands.  Don't go and buy from one brand because not all brands follow the same "standard" in format that Cisco appliance will support.
Hi Leo,
I am using a new compact flash, I bought it to upgrade  the IOS,  I have a 256MB compact flash and its detected by the catalyst but the new one (512 compact flash) no.
Can you recommend me a compact flash brand?
Fidel Gonzalez
No I can't because not all CF "manufacturers" follow the standard.   What I can recommend, however, is to go to your favorite/nearest electronics or camera shop and buy several varieties of CF (up to 2 Gb size) and see which one the supervisor card will detect.
Once detected, use the supervisor card to format the CF.  Return the un-used ones and, optionally, buy more of the ones that work (as spare).
I bought this compact flash model MEM-C6K-CPTFL512M, before bought it, I readed that this model is compatible with cisco.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/prod_end-of-life_notice0900aecd805f990d.html
MEM-C6K-CPTFL512M=
Catalyst 6500 Sup720/Sup32 Compact Flash Mem 512MB
Fidel Gonzalez
InayathUlla Sharieff
Please check if you have any spare CF card and pull one of them from any other spare chasis and test if this switch detects that.
SEcond  i see that the device has booted us with the below reason:
System Returns to ROM by Unknown Reload Cause
The Cisco Catalyst 6000/6500 Switches can unexpectedly reload due to an unknown cause. The output of the show versioncommand displays a similar error message:
boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19 (SP by power-on)
This issue is documented in Cisco bug ID CSCef80423 (registered customers only) . Upgrade the switch to the latest Cisco IOS Software release unaffected by the bug in order to resolve this issue.
Hi Insharie,
My goal is upgrade the IOS, for that reason i want to upgrade it, thanks you for the information about the bug.
Fidel Gonzalez
