11-16-2014 10:42 PM - edited 03-07-2019 09:32 PM
There is latency when performing ping test to the vlan interface IP (gateway IP) from the stackable access switches, Cisco 2960X to core switches C3650S. The ping response time is from 5 ms to 33 ms. The ping from host to host is <1ms. It has uplink throughput is 4Gbps. I have checked the cpu usage/memory and uplink. It looks fine to me.
Anything else I can check. Please advise.
Solved! Go to Solution.
11-17-2014 07:43 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Ping wasn't really designed for performance testing, it was designed more for confirmation that a device is "alive". This being the case, network devices often give little priority to responding promptly to a ping requests, and hardware switches do this on their control plane, which is relatively slow compared to their data plane.
I.e. 5 to 33 ms, from the switch, might be perfectly normal compared to the host ping being less than 1 ms.
11-17-2014 08:46 PM
Agree with Joseph.
Such ping can be normal, in case of the some control plane protection implemented on one of the end network devices between which you sent pings. You can check this by issuing more pings and monitor how RTT will increase with the increasing number of ICMP packets sent.
Example from my network:
SW01#ping x.x.x.x
Sending 5, 100-byte ICMP Echos to x.x.x.x , timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/16/17 ms
SW01#ping x.x.x.x repeat 100
Sending 100, 100-byte ICMP Echos to x.x.x.x , timeout is 2 seconds:
Success rate is 100 percent (100/100), round-trip min/avg/max = 8/26/671 ms
11-16-2014 11:13 PM
1- check Physical layer then ( Interface errors/cabling/patch-panel if there is 0.
2- Then check connecting laptop and ping observe the result.
3- Is this new setup or existing? If existing has this ever worked fine? if yes then what changes(h/w or S/w ) been performed?
11-16-2014 11:16 PM
It is the new setup. All the switch ports are giving the same result. No issue on the physical layer.
11-17-2014 07:43 AM
Disclaimer
Posting
11-17-2014 08:46 PM
Agree with Joseph.
SW01#ping x.x.x.x
