Installing I/O Module into Nexus 7000 Series
I just recently got a 48 port module for our Nexus 7000 series and I was just wondering what the correct installation instructions are. I thought it was merely plug and play but that does not seem to work. When I plug in the module into slot 1, the status light on the module blinks red. When I SSH into the Nexus management and run a "show hardware," it says that module 1 is empty. I tried this for other slots as well. It's as if the module is not being recognized even though it is plugged in (because the status light blinks red).
Any Ideas?
6 Replies 6
Reza Sharifi
What type of module are you installing and what version of software are you using?
Usually it takes a few minutes for the module to go on line
It it does not then you may have a bad module
The module is the N7K-F248XP-25E which is a F2-Series 48 port 1/10G Ethernet. The software version running on the Nexus 7000 is 6.1(2).
I left the module in overnight and it still showed the blinking red light this morning.
Then most likely you have a bad module
Open a ticket with TAC and RMA the module
Ok thank you very much.
I didn't have to enable the slot or anything like that to get it to work right? It should've been just plug and play?
Correct you do not need to do anything.  It should be plug and play. I have installed F2 modules before and it was all plug and play
Dale Miller
When you insert the module do you see any errors in the log?
Please collect show log last 50 and present any messages specific to the problem. I dont expect much if the module is not recognized then most likely no diagnostics even get a chance to run during boot.
Also when you install the card and look for it on the switch are you in the admin VDC?
Dale
