05-11-2021 09:20 AM
Hi, does anyone have instructions for removing the RFID module from the CISCO 9500 switch?
05-11-2021 09:33 AM
as per I know it is a built-in switch, you can not remove, but you can disable i guess - never tried - i will test this command later week on one of the switches,.
no location rfid status
05-11-2021 09:39 AM
Hi, thanks for the command, but I need to remove the physical module from the ejector arm that is part of the system tray. Does anyone have any instructions or tool suggestions?
Thank You
05-11-2021 05:41 PM
Please contact your Cisco AM/SE because physically removing the RFID will automatically void the warranty.
05-11-2021 09:22 AM
Hi, does anyone have instructions for removing an RFID module from a CISCO 9500 switch?
05-12-2021 03:57 AM
not that i am aware any community member can able to help here,. since you looking hardware remove which part of the deal. talk to cisco Rep or partner as suggested, not sure what is the reason for removing, people looking more feature, first time i am hearning removing the feature which protect assets here.
11-08-2022 11:57 PM
just unscrew it....
11-09-2022 12:21 AM
11-09-2022 03:26 AM
nice good luck,.!
