inter VLAN Routing between different switches
ange.essan1
Dear All,
I have an hybrid network that consists in :
  • 01 x CISCO Catalyst 2960-X 24 ports
  • 02 x Mikrotik CR5125-24G-1S-RM
  • 01 x HPE E2620-24
I want to apply network segmentation by creating VLANs and configuring routing between these VLANs.
Is it possible to configure this between these switches that are not from the same manufacturer ?
My own idea is to :
  • Create VLANs on each L2 switch highlighted above
  • Install a L3 switch (Cisco Catalyst 3650 for instance)
  • Connect all the L2 switches on it and configure the InterVLAN (ip routing)
Is it correct ? if no, what are the steps to accomplish this ?
Thanks  in advance.
Deepak Kumar
Yes, it is possible.
  • Install a L3 switch and configure all VLAN and its IP address < Interval Routing must be here>
  • Connect all the L2 switches on it and configure VLANs.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Thank you very much
on a side note, and in addition to Deepak's post, I think the 2960-X has limited routing capabilities and can do SVIs, so you might be able to use that switch as your layer 3 device...
