interface gi 0/25 on a SM-ES3G-24-P
s.balon
I just receive a new Cisco 3925 with a etherswitch module 24 port :  SM-ES3G-24-P
I successfully boot the switch module and gain access to it.
I found some documentation on CCO but I don't sorted out this small information :
Switch#sh cdp neig
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
Router           Gig 0/26          143             R S I  CISCO3925 Gig 2/0
Switch#
The Router is connected to the switch module via a HIMI :
The Cisco enhanced EtherSwitch service modules also provide a physical Gigabit  Ethernet serializer/deserializer integrated circuit transceiver (HIMI)  interface. In the Cisco 2900 series and Cisco 3900 series routers, the HIMI link  on the Cisco enhanced EtherSwitch service modules is connected to the router  internal Gigabit Ethernet backplane. This link is used for interconnection  between other interface cards or network modules attached to the router Gigabit  Ethernet backplane bypassing the router host CPU; thus, increasing CPU  performance by decreasing CPU processing.
If I do a sh ip int brief on the switch, I have 26 interface but only 24 are physicaly present on the front.
The type of the 0/25 and 0/26 are the same : media type is 1000BaseX
The interface gi 0/26 is up up but the 0/25 is down down.
What's the goal of this gi 0/25 interface ?
this is use to connect via the backplane (MGF ???) 2 switching module ? ???
Thanks for help me to clarify.
Steve Balon
s.balon
Any update ??
Can someone help me ??
Thanks in advance.
Steve
Did you find out what gi0/25 and gi0/26 do?
Unfortunatly not..
I leave this interface unused.
Sorry.
Steve
g0/25 is an 'internal' L2 interface from the ES3G to the router Multi-Gigabit Fabric.
g0/26 is an 'internal' L3 interface from the ES3G to the router.
(instead of using a cable from an ES3G switchport to the router)
* used by the router IOS shell to access the ES3G
* can be used to route between the ES3G and the router
