ssh from a 4510 switch to another cisco switch
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-15-2019 02:12 AM - edited 11-15-2019 02:14 AM
hi all,
simple question really how do i go about ssh into another cisco switch when im on a cisco switch
one of my ciscos i can just run this command and it works
ssh user@ip
and it works no problem
but on another switch it doesnt work, this is the error im getting
4510MCR01>ssh user@ip
% Unknown command or computer name, or unable to find computer address
4510MCR01>
thanks,
rob
- Labels:
Catalyst 4000
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-15-2019 02:29 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-15-2019 07:16 AM
4510MCR01>ssh -l rwild 10.110.250.23
[Connection to 10.110.250.23 aborted: error status 0]
4510MCR01>
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-15-2019 11:11 AM
Does the software on this switch support SSH? What is the output of "sh ver"?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-19-2019 09:29 AM
4510MCR01>sh ver
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e -UNIVERSALK9-M), Version 03.10.02.E RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Thu 13-Sep-18 07:38 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.0(1r)SG5
4510MCR01 uptime is 33 weeks, 6 days, 23 hours, 19 minutes
Uptime for this control processor is 33 weeks, 6 days, 23 hours, 21 minutes
System image file is "bootflash:cat4500e-universalk9.SPA.03.10.02.E.152-6.E2.bin"
Jawa Revision 7, Snowtrooper Revision 0x0.0x1C
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Information for 'WS-X45-SUP7-E'
License Level: ipbase Type: Permanent
Next reboot license Level: ipbase
cisco WS-C4510R+E (MPC8572) processor (revision 10) with 2097152K bytes of physical memory.
Processor board ID FOX1609GVNA
MPC8572 CPU at 1.5GHz, Supervisor 7
Last reset from PowerUp
6 Virtual Ethernet interfaces
192 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
4510MCR01>
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-19-2019 09:31 AM
it has got ssh
4510MCR01>ssh ?
-c Select encryption algorithm
-l Log in using this user name
-m Select HMAC algorithm
-o Specify options
-p Connect to this port
-v Specify SSH Protocol Version
-vrf Specify vrf name
WORD IP address or hostname of a remote system
but when i do this command it gets aborted
4510MCR01>
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-19-2019 10:23 AM
Is the encryption match on both switches? if it doesn't make them the same and try again.
You can also try and recreate the key in case something has gone wrong with it.
crypto key generate rsa xxx
