interface vlan different networks
chaname
Frequent Visitor
Frequent Visitor
hi.
I would like to ask for help if anyone knows about network configuration.
Interface vlan is set as below picture.
Although they are different networks, pc1 and pc2 are communicating.
As I understand it shouldn't be able to communicate, what am I missing?
Joseph W. Doherty
Is routing enabled on your L3 switch?  If so, L3 switch will route between directly connected networks.
Joseph W. Doherty
share output of #show ip rout
also enable routing using #ip routing
Good luck
KB
Martin L
On some models of L3 switches routing is disabled by default; enable it with  ip routing or ip routing enable command.
Regards, ML
**Please Rate All Helpful Responses **
if this is GNS3, then try other L3SW image, some image have bug.
your config is OK.
