IOS upgrade for 3850 stack with different hardware versions
krisvamcee
Hi all,
Can I upgrade the below Cisco 3850 stack to Denali 16.3.6 with different h/w versions. I have successfully upgraded for other switches from 03.06.00E version, but there was not much difference in h/w versions (maybe just one version lower). Or the h/w versions doesn't matter?
SW01#show switch
Switch/Stack Mac Address : 6899.cd64.5700 - Local Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
*1 Active 6899.cd64.5700 15 V04 Ready
2 Standby 6899.cdc8.ba00 1 0 Ready
Hi all,
SW01#show switch
H/W Current
Switch Ports Model SW Version SW Image Mode
* 1 56 WS-C3850-48T 03.06.00E cat3k_caa-universalk9 INSTALL
2 56 WS-C3850-48T 03.06.00E cat3k_caa-universalk9 INSTALL
Kris
Kris
johnd2310
Level 8
Level 8
You should be able to upgrade your switch stack. The hardware version does not affect the upgrade.
John
**Please rate posts you find helpful**
Deepak Kumar
You can install the mentioned version but Cisco recommended version is "16.3.7".  So try to go with 16.3.7 if there is no special requirement. If there any special requirement then also visit "cisco feature navigator" to verify that is your required protocol or services available on 16.3.7 or not.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
balaji.bandi
yes you an do that, if this live network, you need 40-50min time to upgrade from 3.X code to 16.X  code
for testing just did yesterday need to document for one of critical place, where people looking for how much downtime we need to ask for business.
its micro code upgrade, took exacatly from time to copy to image to flash to install and come back online 40-50min(includng testing)
BB
Thank you all.
Kris
