Switch port is in errdisable status due to a duplex mismatch
mhiyoshi
Level 3
Level 3
Dear all,
I think recent devices are not supported for errdisable duplex-mismatch feature right?
For example, if I check throught the following command on Cat65-SUP2T however it is not supported.
Cat65-SUP2T#sh errdisable detect
ErrDisable Reason Detection status
udld Enabled port
https://community.cisco.com/t5/networking-documents/switch-port-is-in-errdisable-status-due-to-a-duplex-mismatch/ta-p/3131439
Cat5500> (enable) show errdisable-timeout
ErrDisable Reason   Timeout Status
bpdu-guard          disable
channel-misconfig   disable
duplex-mismatch     enable
I think recently most of cisco devices are not integreted such feature.
Best Regards,
Masanobu Hiyoshi
8 Replies 8
balaji.bandi
I believe that is CATos feature, Not i have seen in IOS.
some reference of error disable available :
https://www.cisco.com/c/en/us/support/docs/lan-switching/spanning-tree-protocol/69980-errdisable-recovery.html
BB
Leo Laohoo
Duplex mismatch won't trigger an error-disable of a port.
What is the output to the command "sh int status err"?
Thank you but it's nothing like this.
Cat65-SUP2T#sh int status err-disabled
Cat65-SUP2T#
[Condition]
Cat65-SUP2T-G1/1(speed 100, duplex ful) ----- G0/10(speed 100, duplex half)-Cat3560G
Is the duplex and speed hard coded in the port configuration?
I am sure but the LC is WS-X6848-GE-TX so the speed auto or fixed are possible.
What is the hard coded meaning? 1G Fixed LC right?
It can't be fibre. It's connected to port 10 on a 3560G. That's a copper port.
Post the complete output to the 6500 command "sh run interface Gi 1/1".
Hi, I replaced "WS-X6848-SFP" but it can not change duplex configuration as follows.
Cat65-SUP2T(config)#int g1/1
Cat65-SUP2T(config-if)#
Cat65-SUP2T(config-if)#speed ?
1000 Force 1000 Mbps operation
nonegotiate Do not negotiate speed
% Unrecognized command
Cat65-SUP2T(config-if)#duplex half
% Invalid input detected at '^' marker.
Cat65-SUP2T#sh run int G1/1
Building configuration...
Current configuration : 66 bytes
interface GigabitEthernet1/1
no ip address
no cdp enable
end
Cat65-SUP2T#
What about the port config of the 3560?
