04-12-2023 07:01 AM
Hi Team ,
We are trying to downgrade IOS on cisco 9606 from 17.8.1 to 17.6.4 but same is getting failed.Below is the device details.Can any one suggest on this.
Chassis Type: C9606R
Mod Ports Card Type Model Serial No.
1 48 48-Port 10GE / 25GE / 50GE C9600-LC-48YL
2 0 Blank Module C9600-SLOT-BLANK N/A
3 0 Supervisor 2 Module C9600X-SUP-2
4 0 Blank Module C9600-SLOT-BLANK N/A
5 0 Blank Module C9600-SLOT-BLANK N/A
6 0 Blank Module C9600-SLOT-BLANK N/A
04-12-2023 07:27 AM
Hi @Robo123
With the 9600X-SUP-2 you have to use a software from 17.8.x and newer:
https://software.cisco.com/download/home/286328203/type/282046477/release/Cupertino-17.9.3
I would use the 17.9.x Train at the moment.
You cant use a 17.6.x on the C9600X-SUP-2
Note: # For C9400X Series (C9400X-SUP-2, C9400X-SUP-2XL), C9500X Series (C9500X-28C8D) and C9600X Series (C9600X-SUP-2), the recommendation is Cisco IOS-XE 17.9.1 or later versions.
04-12-2023 08:50 PM - edited 04-12-2023 08:53 PM
@Feichti Thanks for the replay.Could you please clarify is SUP2 wity 17.7 will support SVL ?I'm not seeing any SVL related commands un device .please clarify
04-13-2023 05:17 AM
You just have to check the documentation on the cisco support, normaly you find all the informations there.
This feature is not supported on the Cisco Catalyst 9600 Series Supervisor 2 Module.
17.9.X:
17.10.X:
Cisco IOS XE Dublin 17.10.1 |
Cisco StackWise Virtual |
Support for this feature was introduced on the Cisco Catalyst 9600 Series Supervisor 2 Module (C9600X-SUP-2). |
17.11.X:
So starting with 17.10.x SVL is for the C9600X-SUP-2 supported. But see in the documentation that there are some hints:
Note: This does not apply to the Cisco Catalyst 9600 Series Supervisor 2 Module (C9600X-SUP-2).
04-12-2023 07:49 AM
Is the supervisor come with that Version ?
If that is the latest - some of the IOS you can not download i guess here ?
by the way what is the reason for downgrade ? what error you getting ?
