IP Accounting
wgranada1
Level 6
Level 6
Good day;
Is there some sort of way that I can do some sort of IP accouting to on a switch
3750 series switch to see who is talking to who and on what port?
Thank you in advance...
6 Replies 6
mahmoodmkl
Level 11
Level 11
HI
U can use ip accouting on this switch as this is a Layer 3 switch.
Mahmood
I've tried that but I don't get anything,
I've let it run for a week and nothing shows up. unless I'm doing something wrong, I have put the ip accounting on the core interface
and still am not receiving anything
what is the version of code on the 3750?
It maybe unsupported command check the following link:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.1_19_ea1/configuration/guide/swuncli.html
Saju
It may not support it , the 3750 does not support netflow either.
the version code on the 3750 is
12.1(11r)AX
Will check the link
dipjitsengupta
Community Member
hi,
pls use 'sh ip accounting" command to get u r required ans...
hope it will work for u..
have a nice day...
